Sign in to follow this
EcoBrick Bob
L.E.D. Daytime Driving Lighting on a Brick
After seeing all those Audi's, BMW's, Porsche's and Merc's running around with LED daytime lighting.... I had to see if I could create the same look on my Brick.
I purchased LED light strips on EBAY. They were under $30. for 2. Note... these are 2 identical ones, rather than opposites. Order issue!
Here they are installed. They normally appear much brighter, but this pix is in very bright sun.
I wired each strip together and hooked them up to a fuse in the underhood fuse box which turns on with the key.
Later I added some vertical 6 light LED's in the corners of the grille next to each headllamp. Never got pix.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
