Sign in to follow this
gpfarrell
Snagged on install
Im trying to load my Stage 4+ from the MyCal to my push button start MKS.
After pushing and holding the start button long enough for the gauges to sweep, I get this error:
"Could not initialize communications with vehicle (1). Check connections and try again"
So I've done that, but keep getting snagged in the same place.
I think my connections are good... It's pulling the cars VIN number and earlier I was doing 0-60 runs and it seemed to be communicating just fine.
Any ideas? I'm dying to try this thing!
Greg
Share this post
Link to post
Two things I learned to look for.
If you got two cables the one you need is the one with the molded blocky lump built into it. I got that wrong the first time.
You must hold the start button in (without stepping on the brake) for several seconds before releasing it. That makes a really big difference and is absolutely mandatory.
If you are doing both of those things and its still not working, I don't know what else to advise but call Rick.
Good luck
Share this post
Link to post
Early today, I needed 5.44 based on an average of 4 runs, 2 each in opposite directions.
Now I need 4.73 figured the same way.
Oh, and the 5.44 was on on fumes and the 4.73 had a full tank of 93... probably 100 lbs of fuel!
If I can do this... with this Forum's help... anybody can!
Share this post
Link to post
I'm assuming your numbers are referring to a 0 to 60 test. If so they are really useful to me. I'm going through a test and evaluate period now where I'm going back to stock to figure out why my car is not performing as expected. For convenience my yardstick comparison test is my 0 to 60 times. The best time I've gotten with 1/4 tank and torque loading the tranny is 5.4 and that's running LMS 4+. So I figure it's easier to find what's holding me back while stock. I don't have a stock 0 to 60 yet so thank you for sharing yours.
Share this post
Link to post
Larrylu, yes those are 0-60 times... My private test track doesn't have enough room for 100 mph 1/4 mile blasts!
If your "track" is slightly uphill, your times will be slower. I ran both ways on mine to compensate for Pennsylvania. Also, if the car creeps a few inches while you are holding it with the brake, the clock starts and your times will quickly be a few tenths longer.
Tuned, my brakes have a hard time keeping the car dead stopped. Stock, it would old still until you let off the brake.
Good luck, and thanks again for the help.
Share this post
Link to post
I wish I had a private test track. I don't think the grade was an issue but your suggestion to check the creeping might be. Think I did creep just a tiny bit before launch. I remember hearing the brakes groan a bit. I will retest before detuning. Thanks for a very good suggestion.
Share this post
Link to post
Glad you got it loaded, gpfarrell! We needed another tuned MKS on this forum. I presume you are pleased with the results of the tune. For what it is worth, I thought mine improved after 150 miles or so - especially transmission operation. It became smoother while still being firm.
For what it's worth, I hit a snag the first time I tried to load my tune. I frantically PM'ed Mark and before he had a chance to answer, I tried it again and it worked fine.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
