Cannot Adjust Speed Compensated Volume?
Hi Guys,
I'm running into an odd problem where my "Speed Compensated Volume" is grayed out, and when I try to adjust it, I get a popup saying, "MyKey may prevent you from changing some settings." I then go into the MyKey settings, and it states that I have zero MyKeys programmed and 2 admin keys. Does anyone know what I can do to fix this?
Your dealer can reset it, but it looks like someone used a different key than the one you had at the time to set up the MyKey functionality.
Great, thanks! I assume the dealer resetting it is a different process than me resetting Sync? Also, do most Ford dealers charge to reset?
