2016 3.5L SHO Hurricane Bundle Install!
Were installing our Hurricane Bundle on this 2016 Ford Taurus SHO 3.5L EcoBoost. This bundle also fits 2013 to 2016 3.5L Taurus SHO, 2013 to 2016 Ford Flex 3.5L Limited and SEL, and 2013 to 2016 Lincoln MKS/MKT 3.5L EcoBoost.
This package consists of our My Calibrator tuner, Even Flo thermostat, Windstorm Cold Air intake and a 3 bar map sensor. These products will allow you to run our powerful 3 bars tunes giving you up to 70hp and 90tq and normally will get your SHO in the 12"s. Get this Hurricane bundle today and make you SHO/MKS into the fun car it was meant to be!
Some details on our MyCalibrator device are located below.
MyCalibrator Tuner:
Custom tuning via Livernois Motorsports (Device stores stock + up to 4 Custom Tunes)
Multiple stages for increased horsepower & torque
Dyno proven air/fuel adjustments
Transmission modifications with reduced torque management and modified shift points/firmness
Enhanced throttle response
Available for multiple fuel octane levels
Removed top speed limiter
Read/Clear (DTC) Codes
We will be going through the rest of the vehicle so stay tuned!
Now that the Stock cold air intake is out of the way, we can access the thermostat. Below is a photo of the stock thermostat.
Now we will be adding the Livernois Motorsports EvenFlo Thermostat. With one of these high performance Livernois Motorsports & Engineering thermostats, you can dramatically reduce the operating temperatures in your performance engine. Using our line of EvenFlo 160° low temperature thermostats for late model performance engines, you can dramatically reduce the operating temperatures in your performance engine. This will allow for the engine to naturally make more power, ensure consistent performance, and increase coolant flow to help extend engine component longevity.
Up next is the Livernois Motorsports Windstorm Cold Air Intake. The stock one is removed and placed out of the way.
More flow equals more power and our Livernois Motorsports Windstorm series intake system gives you the best of both worlds! The Windstorm intake system features a dry and washable high performance filter, a new large, one-piece, rotationally-molded air box and totally redesigned air intake tube. These new one-piece air boxes feature an exclusive air filter which, when combined with the CAD-designed intake tube, provides maximum horsepower, torque, and MPG.
