Steve Posted March 10, 2018 Report Share Posted March 10, 2018 Steve RuderNew Member Hello fellow SHO owners. New to the forum. I have a 2010 SHO with about 77K miles. Getting a cyclical thumping or warmbling noise in the front end. It is getting louder. When I turn the wheel slightly to the right it is much quieter almost gone. Just replaced wheel hub/bearing thinking this was it. Still there. Any help out there as tonthe cause would be appreciated. Quote Link to comment Share on other sites More sharing options...
SHOdded Posted June 15, 2018 Report Share Posted June 15, 2018 Sometimes it is the strut mount/bearing and or the bolts that hold it in place are not properly tightened down. I would rotate the tires, see if the noise moves with it. Maybe the wheel is cracked/unbalanced. Did you use OEM /Motorcraft bearings, or SKF, Timken ...? Other aftermarket brands are often cheaply designed and fail quickly. Did you replace the right bearing or the left bearing? Quote Link to comment Share on other sites More sharing options...
