Sign in to follow this
Blaine109
MyCal Subforum?
Do we have enough interest in having a subforum in the Tuning Section for people using the MyCal device? I think that as more and more people are starting to use this device and explore it's potential it would be nice to have a spot on the forums for MyCal specific questions and discussions.
Share this post
Link to post
I would also recommend a PM to ADMIN, as he is the only one with the ability to go into the software of the forums, and insert that as an option.
I know he's recovery from some recent health related issues, but I'm sure his reply would be relatively quick (as they usually are).
If / when someone does choose to PM ADMIN, let me know when that's been sent / submitted....
If he hasn't replied in a reasonable manner given his recovery period right now, I'll get a hold of him myself and let him know there's an interest in this.
Mike :yo:
Share this post
Link to post
I had same problem, assuming you've already been thru set process where it scans for all available parameters. You have setup up the 0-60 and 1/4 to use the vehicle speed sensor and these performance test will work. I am still quite the novice on setting up. But I put together a how to some time today.
Share this post
Link to post
Ha Crash Ihave a older(old man old laptop) and it will not run the mini cd that came with the MyCal. I'm lucky that LMS send upload/download instuction for the stage 4 or I would've been out of luck. Any help you can give I'll be thankful for, thanks.
Share this post
Link to post
From main menu select setup. NOTE MUST BE IN ACCESSORY MODE TO PERFORM JUST LIKE LOADING TUNE.
next select find signals.
E9E3E58C-64C3-4E33-82E6-A433FEE52946-5496-0000019059F01D32.jpg67D661A6-209E-405F-9B10-656246E24C3E-5496-00000190678A479D.jpg
Now go back out to main menu select acceleration test.
And select setup.
Now touch box where my finger is.
Next make sure you mycal display in light blue across as seen in photo if not us left arrows until you find next go to list below even thing is in alphabetical order and select vehicle speed. and hit save and your done.
Share this post
Link to post
Thanks Chris, there were 2-3 steps that were missing in the how-to, but I got it without troubles... However, once we select vehicle speed, there is no more instructions. So I tried going out to try a few runs (1/8 and 1/4...)... It gives the RT, the time for 1/8 or 1/4, but couldn't find the 0-60 and neither where the run was recorded. I tried user test and it didn't work (ET of 0.06...).
Any more help would be grestly appreciated and step by step, even when it seems obvious, I don't understand what I am missing and it is not intuitive for me.
Thank you very much again!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
