MelC Posted December 25, 2012 Report Share Posted December 25, 2012 What are your primary goals with the adapter' date=' most just to read diagnostic codes or are you wanting to datalog?[/quote'] I would use mine mainly for monitoring and data logging. The reason I asked is there are comments that some of the OBD2 bluetooth on Amazon do not work with late model Fords. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted December 26, 2012 Report Share Posted December 26, 2012 Both of these work with my 2004 Aviator, my 2011 SHO, my wife's 2010 MKT EcoBoost, and the first one also works my co-worker's 2004 Silverado. I haven't let him try the one in the second and third photos. Here is a photo of the one I have that doesn't have all that great of a sampling rate and generates a lot of "faults" with the Torque app (I'm guessing dropped packet faults, not OBD2 faults). There are no stickers or identifying marks on the back of the case. And here is the one that works very well with a good sampling rate and almost no "faults" with Torque. -Rod Quote Link to comment Share on other sites More sharing options...
mhenne4 Posted December 26, 2012 Author Report Share Posted December 26, 2012 This is mine.[ATTACH]1472[/ATTACH] As with most things there are thr good ones and the cheap (sometimes shitty) ones. Based on the research I found online (through amazon) I found a retailer of these out of new york. Most of these cheap ones are out of hong kong. My cheap one seems to work great on the guages (I see no lag in the little refresh light inside each guage) but I have yet to actually run a datalog . Not to hijack but on air to fuel ratio there is 2 different data sets, commanded and measured, what is the difference? Quote Link to comment Share on other sites More sharing options...
SteelBlue402A Posted December 27, 2012 Report Share Posted December 27, 2012 Do you have to purchase the little 4 dollar addon piece with the elm327 or is it bluetooth without it? was lookin on amazon. Thanks Quote Link to comment Share on other sites More sharing options...
EcoBoostSHO Posted December 27, 2012 Report Share Posted December 27, 2012 This is mine.[ATTACH]1472[/ATTACH] As with most things there are thr good ones and the cheap (sometimes shitty) ones. Based on the research I found online (through amazon) I found a retailer of these out of new york. Most of these cheap ones are out of hong kong. My cheap one seems to work great on the guages (I see no lag in the little refresh light inside each guage) but I have yet to actually run a datalog . Not to hijack but on air to fuel ratio there is 2 different data sets, commanded and measured, what is the difference? The commanded is what the car wants the air fuel ratio to be based on conditions (engine load/temp/MAP etc.)...measured is what the car is actually reading in the exhaust. Ideally you want them the same but in reality that won't often happen. That said my car is pretty accurate most of the time. Back on topic...the cheaper adapters will usually work just fine but the more expensive ones typically have much faster update rates which is usually better for scanning /real time applications. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted December 27, 2012 Report Share Posted December 27, 2012 Do you have to purchase the little 4 dollar addon piece with the elm327 or is it bluetooth without it? was lookin on amazon. Thanks As long as it has the little Bluetooth logo on it you shouldn't need any add on piece. -Rod Quote Link to comment Share on other sites More sharing options...
