shomeda- Posted February 23, 2013 Report Share Posted February 23, 2013 I went to tirerack.com and looked at some wheels for the SHO.. They state that the following wheel config will work on the SHO: Offset: 30mm Backspacing: 6.02" Bolt Pattern: 5-114 So my question is, will wheels with the following specs work on the SHO? Size 20x9 Offset: 18mm Pattern: 5x115 with 71.5 Bore OR 5x139.7 with 78.1 mm Bore Please let me know as I want to make a purcase soon Quote Link to comment Share on other sites More sharing options...
83racecrew Posted February 23, 2013 Report Share Posted February 23, 2013 I don't know with 100% certainty, but, no they won't. Lug pattern is wrong, it NEEDS to be 5-114. Also the offset should be near 34mm for caliper clearance. Quote Link to comment Share on other sites More sharing options...
Sneaktip Posted February 24, 2013 Report Share Posted February 24, 2013 Not at all!!! Offset is to low, bolt pattern off and hub size is to big. You could have adapters made but highly not recommended. Quote Link to comment Share on other sites More sharing options...
