travSHO Posted February 28, 2013 Report Share Posted February 28, 2013 I have watched a few of the vidoes on the net for the SHO and in most of them it looks like at the end of the 1/4 the person would put it in M instead of just leaving in in D. They all were runs done in D. Is there a reason for this that I dont know??? Thanks Quote Link to comment Share on other sites More sharing options...
mhenne4 Posted February 28, 2013 Report Share Posted February 28, 2013 My guess would be that you can downshift and use the tranny to reduce your speed instead of jumping on the brakes. I believe truckers use this practice. Quote Link to comment Share on other sites More sharing options...
racerx78 Posted February 28, 2013 Report Share Posted February 28, 2013 I have watched a few of the vidoes on the net for the SHO and in most of them it looks like at the end of the 1/4 the person would put it in M instead of just leaving in in D. They all were runs done in D. Is there a reason for this that I dont know??? Thanks Probably because for doing other driving in the car the, like at a track. The care is more responsive when driven in manual mode, but doing typical drag runs and 0-60 Full auto typically works best. My guess would be that you can downshift and use the tranny to reduce your speed instead of jumping on the brakes. I believe truckers use this practice. Semi's do it and so do trucks/jeeps off roading. Typically you would want to do it in a car unless your on a track or there a problem with your brakes and you need to stop. Engine braking puts more strain on the tranny. Quote Link to comment Share on other sites More sharing options...
travSHO Posted February 28, 2013 Author Report Share Posted February 28, 2013 Yeah I figured it had something to do with the rev match in the manual mode. I don't remember seeing them put it in M and then using the paddle shifters to downshift to use the engine to brake. Could be wrong though. And yeah, 18-wheelers have a jake-brake. Same concept I guess. Quote Link to comment Share on other sites More sharing options...
