kcobra Posted May 7, 2012 Report Share Posted May 7, 2012 Anybody hear a weird like air leaking or sucking noise every once and a while when the car has the climate ac on? Almost like a vacuum leak suction noise. Doesn't do it often. Almost like it's sampling the cabin temp or something. Quote Link to comment Share on other sites More sharing options...
Jojomofo21 Posted May 7, 2012 Report Share Posted May 7, 2012 Mine does it as well. The seat a/c is also very loud when blowing. Quote Link to comment Share on other sites More sharing options...
SonicsSHO Posted May 7, 2012 Report Share Posted May 7, 2012 Had that and eventually the AC condenser went completely. I was told it's a somewhat common issue. Ford even changed the condensers they were using. I found this out the hard way as it took a month to fix! Had to ship the new one from Canada. Quote Link to comment Share on other sites More sharing options...
larrylu Posted May 7, 2012 Report Share Posted May 7, 2012 The seat cooling is a separate small blower located under the seat that blows cabin air through the perforated seat insert panels and is not connected with the A/C. You can hear it running easily especially on high. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jojomofo21 Posted May 7, 2012 Report Share Posted May 7, 2012 The seat cooling is a separate small blower located under the seat that blows cabin air through the perforated seat insert panels and is not connected with the A/C. You can hear it running easily especially on high. Sent from my iPhone using Tapatalk Yes I know this. I was merely stating that it is also annoying. Quote Link to comment Share on other sites More sharing options...
kcobra Posted May 7, 2012 Author Report Share Posted May 7, 2012 Wow, maybe I should be buying the Premium care plan. 300 miles left on warranty and I'm almost afraid. Had that and eventually the AC condenser went completely. I was told it's a somewhat common issue. Ford even changed the condensers they were using. I found this out the hard way as it took a month to fix! Had to ship the new one from Canada. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted May 7, 2012 Report Share Posted May 7, 2012 I hear that same sucking sound every time I get within 100 miles of Washington DC!! Quote Link to comment Share on other sites More sharing options...
Jojomofo21 Posted May 8, 2012 Report Share Posted May 8, 2012 Wow' date=' maybe I should be buying the Premium care plan. 300 miles left on warranty and I'm almost afraid.[/quote'] I got the 5 year 100k just as insurance. Quote Link to comment Share on other sites More sharing options...
