Watts Posted August 7, 2012 Report Share Posted August 7, 2012 Sorry if I missed it - what's the offset? Link to comment Share on other sites More sharing options...
First-SHO Posted August 7, 2012 Author Report Share Posted August 7, 2012 Sorry if I missed it - what's the offset? +36 Front and +42 rear. Link to comment Share on other sites More sharing options...
Watts Posted August 8, 2012 Report Share Posted August 8, 2012 can you tell how much clearence you have to the front strut on the inside? I'm wondering if a 20x10 +40 offset would fit on the front - but that would mean 10mm close to the strut than yours. Link to comment Share on other sites More sharing options...
First-SHO Posted August 8, 2012 Author Report Share Posted August 8, 2012 I don't think those would fit. I have about .300 to strut max. Link to comment Share on other sites More sharing options...
Watts Posted August 8, 2012 Report Share Posted August 8, 2012 Bummer...thanks for the input. I'm struggling to find a 9.5 wide wheel that's relatively inexpensive and looks good. I may have to go staggered to fit my taste. **Maybe i shoudl get a SHO before worrying about it! Link to comment Share on other sites More sharing options...
Watts Posted August 8, 2012 Report Share Posted August 8, 2012 Sorry for all the questions - I'm curious why you went with 42 offset in the front and 36 in the rear. Seems from BPD's setup and those running spacers that there is more room in the rear to the wheel arch than in the front. Link to comment Share on other sites More sharing options...
First-SHO Posted August 8, 2012 Author Report Share Posted August 8, 2012 Because I wanted the same spacing I had with my winter wheels. For looks for the most part. Link to comment Share on other sites More sharing options...
Crash712us Posted August 8, 2012 Report Share Posted August 8, 2012 Sorry for all the questions - I'm curious why you went with 42 offset in the front and 36 in the rear. Seems from BPD's setup and those running spacers that there is more room in the rear to the wheel arch than in the front. BPD wheels are stagger by rim width, 9" in front and 10" in the rear. If I am not mistaken, so no spacers just different sized tires front and rear. But I caution you to do your home work if you plan to do a staggered wheel set up. Tire diameters have to be with in a certain spec of each other, example a 245-45-20 and a 255-45-20 you would think the only thing differs between these to tire sizes is the width. But this isn't necessarily true, it depends on tire manufacture. Diameters change when increasing width, and this why I say to do your home work the AWD drive system only allows for a small difference between tire diameters. Its something most people arent aware of until the have a blow out and take to a tire shop and your told you have to replace all your tires. Link to comment Share on other sites More sharing options...
bpd1151 Posted August 8, 2012 Report Share Posted August 8, 2012 Correct! Doing you homework when it pertains to AWD's systems and staggered sets are a MUST! That being said, my front's are actually 8.5's and the rear's are 10's. Both at a 40mm offset. More info can be found in my thread on my staggered wheel set up (along with pics). Good luck :thumb: Link to comment Share on other sites More sharing options...
Watts Posted August 8, 2012 Report Share Posted August 8, 2012 Yep! I'm aware of staggered requirements on awd vehicles...I drive a wrx now. I'm planning 8.5 in the front and 10 in the rear same as bpd with a bit lower offset up front so it's more flush. Nothing set in stone yet of course since I don't own a SHO - that's still a few months out. Just research at this point. Link to comment Share on other sites More sharing options...
