SonicsSHO Posted June 21, 2012 Report Share Posted June 21, 2012 I am now a BIG fan of this wax. I had never heard of it before until a buddy of mine with a stable of BMW's told me to pick some up! It went on and off easier than any wax I've used previously, and man does my SHO look good! [ATTACH=CONFIG]744[/ATTACH][ATTACH=CONFIG]745[/ATTACH][ATTACH=CONFIG]746[/ATTACH][ATTACH=CONFIG]747[/ATTACH][ATTACH=CONFIG]748[/ATTACH] gregoire 1 Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted June 21, 2012 Report Share Posted June 21, 2012 I'm right there with you. This is all I've used for the past 3 years and with 3 black vehicles (SHO included). Just wait until 4 months from now you wash the car and it still beads water better than most waxes do when freshly applied. Then you'll really be impressed. -Rod Quote Link to comment Share on other sites More sharing options...
fueld13 Posted June 21, 2012 Report Share Posted June 21, 2012 This is great to hear! I just received my 845 a couple days ago (thanks to SHO rods suggestion), I haven't had a chance to try it out yet, I can't wait! Quote Link to comment Share on other sites More sharing options...
tss Posted June 21, 2012 Report Share Posted June 21, 2012 I have used it too - great product. Actually incredible product. I don't know why, but I found it more difficult to work with than traditional polishes/waxes. So I have been using Zaino for the past 6 or so years. Maybe the formula changed since 2006 and it is easier to use ? My issue was not in applying, but removing. Took a long time to get rid of the "greasy" smudges as I recall. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted June 21, 2012 Report Share Posted June 21, 2012 Took a long time to get rid of the "greasy" smudges as I recall. Not that the 845 ever really hazes over like conventional wax, but it sounds like you may have been trying to buff it off too early. You also do need to rotate the buffing microfiber fairly regularly, but I'd bet the issue was not letting it dry long enough. -Rod Quote Link to comment Share on other sites More sharing options...
tss Posted June 21, 2012 Report Share Posted June 21, 2012 That is definitely possible. Or maybe it was too humid out. Quote Link to comment Share on other sites More sharing options...
SonicsSHO Posted June 21, 2012 Author Report Share Posted June 21, 2012 I have used it too - great product. Actually incredible product. I don't know why' date=' but I found it more difficult to work with than traditional polishes/waxes. So I have been using Zaino for the past 6 or so years. Maybe the formula changed since 2006 and it is easier to use ? My issue was not in applying, but removing. Took a long time to get rid of the "greasy" smudges as I recall.[/quote'] I believe it suggests you only do 2x2 sections at a time....I however went much bigger, and therefore let the wax dry a bit longer. It was humid as heck here yesterday and it didn't seem to effect it a bit. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted June 22, 2012 Report Share Posted June 22, 2012 I generally apply the 845 to an entire panel at a time (hood, or trunk, or roof, etc), then rotate between buffing and applying. After applying to the first panel, I'll treat the tire sidewalls, then apply to a second panel, buff the first, apply to a third panel, etc. But I also do this in my air conditioned garage so humidity isn't a problem. -Rod Quote Link to comment Share on other sites More sharing options...
gregoire Posted June 26, 2012 Report Share Posted June 26, 2012 Thanks for posting, ordered some, cant wait to try it out. Quote Link to comment Share on other sites More sharing options...
