penneyr Posted June 24, 2012 Report Share Posted June 24, 2012 How do you get the wiper arms off to remove the cowl? Link to comment Share on other sites More sharing options...
darreli Posted June 24, 2012 Report Share Posted June 24, 2012 There's a plastic cap on the wiper arm where it meets the cowl. Pull that off and there's a nut underneath it. Think it's like 15mm if I recall. Then you can pull it off but it's way easier if you have a small puller (two arm type like a battery cable puller) Link to comment Share on other sites More sharing options...
Crash712us Posted June 24, 2012 Report Share Posted June 24, 2012 I'll second what darrell said, they wiper arms sit on them spindles very tight and need persuasion to remove. Link to comment Share on other sites More sharing options...
penneyr Posted June 24, 2012 Author Report Share Posted June 24, 2012 Thank you all, will make a run to Napa tommorow. Link to comment Share on other sites More sharing options...
penneyr Posted June 25, 2012 Author Report Share Posted June 25, 2012 Thanks again, got the cowl off, ran my amp wire, and back on without a hitch. Link to comment Share on other sites More sharing options...
