larrylu Posted July 6, 2012 Report Share Posted July 6, 2012 I've been having some inconsistent behavior from my keypad. Swiping motion works like a charm to unlock but the two finger on the bottom numbers to lock has been real iffy. With repeated attempts I can usually get it to lock but frustration often sets in. Dealer has replaced the pad with no improvement. Last time the dealer could not duplicate the problem. It is like 50 / 50 for me too so I'm not surprised. Any one else have any experience to share on this issue? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Crash712us Posted July 6, 2012 Report Share Posted July 6, 2012 Heck I wasn't even aware I could lock my car from the key pad. Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted July 6, 2012 Report Share Posted July 6, 2012 Heck I wasn't even aware I could lock my car from the key pad. Yep..... Ford's keypads (as far as I'm aware) have ALWAYS locked by simultaneously depressing the 7/8 and the 9/0 at the same time. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted July 6, 2012 Report Share Posted July 6, 2012 Yep, every Ford keypad I've see since the early '90's has locked by pressing the 7/8 and 9/0 simultaneously. I never had problems with the locking feature on the old membrane style, but I've also experienced iffy locking performance with the current touch sensitive style. What seems most reliable for me is the put the tip of my thumb on the 7/8, then roll my thumb to cover the 9/0 buttons. Generally the locks lock reliably this way. Trying a two-finger method works maybe 40% of the time for me. -Rod Quote Link to comment Share on other sites More sharing options...
double c Posted July 6, 2012 Report Share Posted July 6, 2012 Hve found that using one finger-between first and second knuckles-works almost 100% Sort of make fist and keep index finger knuckle extended to contact 7/8..9/0. Key has to be in proximity-if i extend full arm with key in pocket it may not work. Easier than trying to get two fingers on simultaneously. Quote Link to comment Share on other sites More sharing options...
SpoolinX2 Posted July 6, 2012 Report Share Posted July 6, 2012 I use my thumb to hit the two buttons simultaneously. As others have said, the 7/8 and 9/0 together lock the car. Not sure if anyone else knows these other tricks, but if you put in your code, followed by 3 will unlock all doors, and the code followed by 5 will unlock the trunk. I've surprised a lot of people like this in the past with my Fords, haha. Quote Link to comment Share on other sites More sharing options...
larrylu Posted July 6, 2012 Author Report Share Posted July 6, 2012 Thanks for all the great replies. I feel better knowing I'm not the only one to wrestle with this odd behavior. I tried the several finger placement methods suggested and Spooling's trick of the thumb covering both sets of numbers worked perfectly for me every time so that will be the new drill. Thanks again everybody. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted July 6, 2012 Report Share Posted July 6, 2012 Yeah, same here, sometimes 2 fingers work great to lock and sometimes I have to use the thumb and kinda roll over both numbers to get it to lock. Also don't forget that you can unlock the trunk by entering your code and then hitting the 5-6 button after the code and the trunk will unlock! Quote Link to comment Share on other sites More sharing options...
larrylu Posted July 6, 2012 Author Report Share Posted July 6, 2012 So far I've used the code only the one time I left the fob in the car and locked it. It was good to have the code. If I want to open the trunk, I feel it's easier and faster, for me anyway, to use the trunk button under the plate, or the fob, or the dash button depending on where I am or what I'm doing at the time. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
wildosvt Posted July 7, 2012 Report Share Posted July 7, 2012 No need to enter the code folks. If you swipe the keypad then hit 3 all door unlock and then hit 5, The trunk unlocks. Quote Link to comment Share on other sites More sharing options...
EcoBrick Bob Posted July 7, 2012 Report Share Posted July 7, 2012 Mine has locked by itself... when I am washing car and run mitt over the keypad... Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted July 7, 2012 Report Share Posted July 7, 2012 So far I've used the code only the one time I left the fob in the car and locked it. It was good to have the code. If I want to open the trunk, I feel it's easier and faster, for me anyway, to use the trunk button under the plate, or the fob, or the dash button depending on where I am or what I'm doing at the time. There have been several times when I wanted to get into the trunk and I didn't really need to get into the interior and I didn't have the fob with me, that's when I use the keypad. Quote Link to comment Share on other sites More sharing options...
IowaFoSho Posted July 7, 2012 Report Share Posted July 7, 2012 I put my nose on the 7/8 and use my tongue making circles in a counter clockwise motion on the 9/0. This usually works. My wife loves it. Quote Link to comment Share on other sites More sharing options...
Bigjht Posted July 7, 2012 Report Share Posted July 7, 2012 I put my nose on the 7/8 and use my tongue making circles in a counter clockwise motion on the 9/0. This usually works. My wife loves it. .......... :laugh: Quote Link to comment Share on other sites More sharing options...
EcoBrick Bob Posted July 7, 2012 Report Share Posted July 7, 2012 Love that IA SHO.... but I wasn't kidding (like I normally do about everything) when I locked the car with my wash mitt. Luckily, I had the extra set of keys in the house... First thought they might be in FLA... And I have long forgotten my touch pad code... Never use it. Quote Link to comment Share on other sites More sharing options...
penneyr Posted July 7, 2012 Report Share Posted July 7, 2012 Brick you should be able to enter your own code. In case it happens again. Use it on the F150 all the time. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted July 7, 2012 Report Share Posted July 7, 2012 Love that IA SHO.... but I wasn't kidding (like I normally do about everything) when I locked the car with my wash mitt. Luckily' date=' I had the extra set of keys in the house... First thought they might be in FLA... And I have long forgotten my touch pad code... Never use it.[/quote'] Forgotten the code, I put in a code that I can't forget...but then again at your age EBB you might have that old-timer's thing going on!:dizzy: Quote Link to comment Share on other sites More sharing options...
The Bone Posted July 10, 2012 Report Share Posted July 10, 2012 My wife locked her fob in the car the other day and the car unlocked the doors and sounded the horn Quote Link to comment Share on other sites More sharing options...
tss Posted July 10, 2012 Report Share Posted July 10, 2012 ^^ If the fob is on your body, yes. But, I like to leave the fob in the car if I am, for instance, going running at a park. Not really a tip, but helps me remember better: Instead of remembering the "3" opens all doors, I remember that the "4" opens all "4" doors. Easier for me to remember that way. Quote Link to comment Share on other sites More sharing options...
tss Posted July 10, 2012 Report Share Posted July 10, 2012 My wife locked her fob in the car the other day and the car unlocked the doors and sounded the horn I believe it only does that if the fob is in the trunk. Not positive though. I lock my car almost everyday with the pad with the fob inside the center cupholder area. Quote Link to comment Share on other sites More sharing options...
SpoolinX2 Posted July 10, 2012 Report Share Posted July 10, 2012 If you leave the keys anywhere in the car and lock the doors with the lock button inside, it will do that. I guess it's a way of saying "hey, forgetting something?" However, if you leave the keys in the car, and lock it with the 7/8-9/0 button combo, it will lock. Quote Link to comment Share on other sites More sharing options...
tss Posted July 10, 2012 Report Share Posted July 10, 2012 ^^ You are right. But, if you leave the keys in the trunk and try to close the trunk, I seem to recall it doing the same thing - beeps twice and you need to slam the trunk a second time, as it does not lock the first time. Quote Link to comment Share on other sites More sharing options...
SpoolinX2 Posted July 10, 2012 Report Share Posted July 10, 2012 I believe I remember that happening one time. Correct. Quote Link to comment Share on other sites More sharing options...
tss Posted July 10, 2012 Report Share Posted July 10, 2012 ^^ I remember being really annoyed by it because I bought an extra fob and programmed it, and then left it in my trunk until I had time and I could bring the blank uncut "emergency" key inside to a key shop to cut it. For like 3 days, the trunk yelled (beeped twice) at me and wouldn't lock on the first slam. LOL. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted July 10, 2012 Report Share Posted July 10, 2012 I have to credit my wife with this, she made the dealer throw a 3rd fob in with the car purchase, so we have 3 for the SHO. It they programmed it during an oil change visit at no charge, so we have the fob covered, only problem I have had was a few times the car failed to recognize the fob was in my pocket so I had to lay it on the seat before the car would start. Quote Link to comment Share on other sites More sharing options...
