Sign in to follow this
EcoBrick Bob
Visual Garage Shark Fin Flex Antenna
I was the first person to install a Visual Garage Shark Fin Antenna. I had purchased and installed 2 of these antenna covers on my G8's.
So I contacted Visual Garage about one for my Brick. It is requires the same size cover, but needs to have a FLAT base, instead of slightly curved on the G8 design. They asked for a pix of the stock antenna showing the flat sorrounding area. Since they were already doing other Ford products, they had White Suede paint on hand. About 3 weeks later my Shark Fin arrived. Here are some pix. The cost was under $85. shipped.
Before...
The underside showing the actual antenna+ the screw that hooks the loop to the original antenna block.
Installed pix...
Gets rid of the cheap looking factory antenna for under $100!:biggrin1:
Unfortunately, it doesn't fit well on the Flex without the glass roofs.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
