G03svt Posted November 19, 2012 Report Share Posted November 19, 2012 Wheel Specs Diameter [?] Width [?] Finish Lugs [?] Offset [?] Backspacing [?] Bolt Circle [?] 19 inch 9.5 inch Silver 5 +35 mm. 6.63 in. 4.5 in. Wheel Specs Diameter [?] Width [?] Finish Lugs [?] Offset [?] Backspacing [?] Bolt Circle [?] 19 inch 9 inch Hyper-Coated 5 +42 mm. 6.66 in. 4.5 in. Quote Link to comment Share on other sites More sharing options...
racerx78 Posted November 19, 2012 Report Share Posted November 19, 2012 I'd use the the fitment calculator at Rim-N-Tires its about the best one i've see out there for finding what fits. I believe the OEM wheel size is 20x8 5x114.3 39mm offset. Quote Link to comment Share on other sites More sharing options...
G03svt Posted November 19, 2012 Author Report Share Posted November 19, 2012 Thanks that link is very useful. Quote Link to comment Share on other sites More sharing options...
racerx78 Posted November 19, 2012 Report Share Posted November 19, 2012 No problme, i hope you find what your need. Quote Link to comment Share on other sites More sharing options...
G03svt Posted November 19, 2012 Author Report Share Posted November 19, 2012 I was seeing if any of the aftermarket wheels from a '05+ Mustang GT would fit and they all run 19" and I currently have the 20" optional rims (non pp). I really like the idea of running a lighter wheel, as my BBS RK Plasma wheels on my Cobra are under 20lbs each and my Bogart drag rims are even lighter then that but I don't use them on the street. My thinking was to keep the stock wheels for winter duty and go with a lighter wheel and more of a performance tire for summer. Quote Link to comment Share on other sites More sharing options...
