Slowsho Posted December 5, 2012 Report Share Posted December 5, 2012 So got in the intake the other day. Real easy install but the temp sensor doesn't fit tight. The screw and washer it gives you to lock it down doesn't do much. Idk if its just me but seems like I could almost pull it out if I wanted too. Doesn't lock down like the stock air box does .Thanks Quote Link to comment Share on other sites More sharing options...
tss Posted December 5, 2012 Report Share Posted December 5, 2012 Mine locks down pretty tight with the harware supplied with the kit - really tight in fact. Maybe you should use a larger screw if the hole is perhaps stripped or too large. Quote Link to comment Share on other sites More sharing options...
Crash712us Posted December 5, 2012 Report Share Posted December 5, 2012 Hmm is the oil ring still on the air temp sensor? Also the sensor has a tab that aligns with notch, the washer and screw merely holds tab in alignment notch. But should fit snuggley in hole. Quote Link to comment Share on other sites More sharing options...
MelC Posted December 5, 2012 Report Share Posted December 5, 2012 Hmm is the oil ring still on the air temp sensor? Also the sensor has a tab that aligns with notch' date=' the washer and screw merely holds tab in alignment notch. But should fit snuggley in hole.[/quote'] It's funny you mentioned the oil ring...I was messing with my intake late last night and dropped the oil ring inside the engine bay and cannot find it. Now it's wobbly...any idea where I can get a replacement? Thanks, Quote Link to comment Share on other sites More sharing options...
Crash712us Posted December 5, 2012 Report Share Posted December 5, 2012 Auto parts sell assortments of O-rings. And if remember correctly its green which same as used in A/C systems. But for its duty anyone that fits will work. Just put a little lube on first so it don't roll when installing. Quote Link to comment Share on other sites More sharing options...
