Boggus Posted March 16, 2013 Report Share Posted March 16, 2013 What it is: Oil blow by, which causes oil to build up in the intake. By adding a catch can to the PCV system it helps eliminate this issue by capturing the oil in the can before it gets cycled through to the intake. This not only keeps the intake cleaner, but it also has the benefit of not causing the cars computer to pull timing, which can happen if there is excess oil in the intake. Other terms: A catch can basically collects excess oil that is sucked out of the crankcase via the PCV valve, it sits inline and instead of allowing oil to return to the intake manifold to be reburned by the engine it collects it in a catch can. Also keeps your Throttle body cleaner. No performance increase however. ---------------------------- Did this on my Dodge Charger, what about a Ford? Every few of oil changes I would need to empty the can. Dodge had a central PCV valve that returned vapor to the intake. Not sure how ford does it but I see two lines running into the intake. Quote Link to comment Share on other sites More sharing options...
slideoil Posted March 16, 2013 Report Share Posted March 16, 2013 I'm very interested in this. Rumor has it, Ford has one on the engine already that drains back to the oil pan, but if the intake manifold still gets crudded, there must be room for improvement. Quote Link to comment Share on other sites More sharing options...
Crash712us Posted March 16, 2013 Report Share Posted March 16, 2013 This subject has been discussed at length before, and for the life of me I can't find as of yet. Will continue to search or perhaps someone else will find and post here. Quote Link to comment Share on other sites More sharing options...
