dbulldog Posted March 24, 2013 Report Share Posted March 24, 2013 Hi everyone! I've searched and have not been able to find the answer but can someone tell me if: a) The SCT X3 tune ordered from LMS writes to volatile memory? In other words, does the PCM retain the tune if the battery is disconnected? Does the tune replace the 'As-Build' code in the PCM? c) If ( is the case, has anyone blanked their PCM as a result of a corrupted upload? Thanks again! Brian Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted March 24, 2013 Report Share Posted March 24, 2013 a) The LMS tune (and all others also) writes to non-volatile memory, so it is retained if the battery is disconnected. The tune replaces the as built code in the PCM, but the stock code is stored on the SCT so that it can be returned to "as built" when needed. c) I think one of the members did, but can't remember. There is an inherent risk (just like updating BIOS in a PC) that if you don't follow the instructions, or lose power during the upload that it will corrupt the PCM. Quote Link to comment Share on other sites More sharing options...
dbulldog Posted March 24, 2013 Author Report Share Posted March 24, 2013 Thanks Leadfoot! Quote Link to comment Share on other sites More sharing options...
