dalum Posted April 15, 2013 Report Share Posted April 15, 2013 I have Eibach's waiting to go on my car but have a few questions first. Does anyone have the torque specs for all the bolts I'll be removing? For that matter does anyone know where I can get the whole cars service manual (hopefully digital)? All I can find is a 2011 so far on alldata but I've seen others post diagrams for '13 before. I might make another thread for this. I read the Eibach's probably won't need an alignment after install. Is there anything I'm taking off during the install that would change the alignment or any positions I need to be careful to put back the same way? I already looked at the sticky for the older setup. Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted April 15, 2013 Report Share Posted April 15, 2013 I have Eibach's waiting to go on my car but have a few questions first. Does anyone have the torque specs for all the bolts I'll be removing? For that matter does anyone know where I can get the whole cars service manual (hopefully digital)? All I can find is a 2011 so far on alldata but I've seen others post diagrams for '13 before. I might make another thread for this. I read the Eibach's probably won't need an alignment after install. Is there anything I'm taking off during the install that would change the alignment or any positions I need to be careful to put back the same way? I already looked at the sticky for the older setup. I think I read 200lb/ft on the bolts for the bottom of the strut, but don't quote me on that. The fronts are a lot easier on the 2013 than the previous years as they changed the strut design. The rears are the same as before. 2 bolts on the bottom of the strut, one on the sway bar (be careful as it does have a little tension on it) and the 4 that hold the strut on the top. The 2 main bolts are a pita, they are splined so a hammer is needed to drive them out once you get the nuts off. I have no idea where to get the manual. But I would love to get one also. Good luck! Quote Link to comment Share on other sites More sharing options...
dalum Posted April 15, 2013 Author Report Share Posted April 15, 2013 I just found this 2013 Taurus Service Information CD-ROM Think its what we need? Quote Link to comment Share on other sites More sharing options...
Boggus Posted April 16, 2013 Report Share Posted April 16, 2013 2013's are easy to install-and I would recommend an alignment after any spring install. Mine tracked straight but the steering wheel was slightly off. Quote Link to comment Share on other sites More sharing options...
