boltmann Posted May 22, 2013 Report Share Posted May 22, 2013 I only have had my SHO for a few weeks and just discovered (read in the owners maunual) the "AdvanceTrac Off / Sport Mode" by holding the break and hitting the "Trac Control" button twice quickly. Has anyone tried this mode at the strip? How did it work for you. I new about hitting it once for "trac control" off and holding it down for 5 seconds for "advance trac" off but not the quickly hitting twice while holding the break for "AdvanceTrac Off / Sport Mode". I have also tried shifter in "Sport Mode". Any Comments would be helpful. Quote Link to comment Share on other sites More sharing options...
83racecrew Posted May 22, 2013 Report Share Posted May 22, 2013 Twice quickly just makes the Advance Trac less sensitive, holding for 5 seconds turns it completely off. Advance Trac is the part where it straightens you out if you get sideways, so it should have no real effect at the 1/4 mile. With it off you could toss it around a twisty curvy track and get it to slide sideways, like the Carl Edwards commercials. With it partially disabled you can get the car to slide a bit, but it still corrects. I tested it out rather extensively this past winter. Quote Link to comment Share on other sites More sharing options...
