Boosted10 Posted June 21, 2013 Report Share Posted June 21, 2013 Just picked my car up from getting an oil change and the tires rotated and balanced. The service manager broke the news that 2 of my wheels are bent on my 10 MKS. The car didn't have any vibration before it was serviced and now it is noticeable at speeds over 55. I don't understand if they where bent why I couldn't feel it before the visit to the dealer. Quote Link to comment Share on other sites More sharing options...
Wild13EcoBoost Posted June 22, 2013 Report Share Posted June 22, 2013 That sucks. Did you get the tire/wheel warranty? If the bent wheels were on the rear than you probably wouldn't notice them as much or if they tried to balance them it could have made it worse. Quote Link to comment Share on other sites More sharing options...
Boosted10 Posted June 22, 2013 Author Report Share Posted June 22, 2013 I bought the car last December, so I'm not sure on the waranty. They moved them both to the rear and it made things worse. It does suck at $1400 per wheel. Hopefully there is someone in KC that is reasonable and can fix them Quote Link to comment Share on other sites More sharing options...
Boosted10 Posted June 22, 2013 Author Report Share Posted June 22, 2013 I tried putting them both back to the right side before I left for work and still noticeable vibration. When I pulled the wheel I looked it over but couldn't see any visible damage. Quote Link to comment Share on other sites More sharing options...
Boosted10 Posted June 23, 2013 Author Report Share Posted June 23, 2013 Pulled every wheel and looked them over and only one showed a slight bend on the inside. Made sure it was on the back and that all the wheels where centered. Torqued them at 40, 80 and 100 lbs then went for a test drive. It is rolling a lot smother now Quote Link to comment Share on other sites More sharing options...
