GUZZI SVT Posted January 2, 2014 Report Share Posted January 2, 2014 If my car is at idle the heated air goes to cool, rev the engine and all is well. Any help? I have heard about the water pump impellor going bad. Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted January 3, 2014 Report Share Posted January 3, 2014 start with checking the coolant level Quote Link to comment Share on other sites More sharing options...
GUZZI SVT Posted January 7, 2014 Author Report Share Posted January 7, 2014 Coolent looks good. Is there a way to burp the cooling system? The system was opened up once during maintenance Quote Link to comment Share on other sites More sharing options...
markssho Posted January 7, 2014 Report Share Posted January 7, 2014 I've noticed the same issue lately. However I've found that if I turn the climate control off for a few seconds and then back on, everything is OK. This makes me think it is the common air door issue in the HVAC unit. I'll get it checked out next time I get an oil change. Quote Link to comment Share on other sites More sharing options...
CV_sho Posted January 10, 2014 Report Share Posted January 10, 2014 If my car is at idle the heated air goes to cool, rev the engine and all is well. Any help? I have heard about the water pump impellor going bad. Noticed the same thing w mine the other night, had it set on vent/floor, thought it was a bit weird, haven't tried cycling the climate control into/out of auto. Quote Link to comment Share on other sites More sharing options...
SHOdded Posted January 10, 2014 Report Share Posted January 10, 2014 As mentioned earlier in the thread, also check coolant levels. May need to burp to get any air out of the system. Is your coolant temp gauge behaving normally? Quote Link to comment Share on other sites More sharing options...
GUZZI SVT Posted January 14, 2014 Author Report Share Posted January 14, 2014 How do you burp it? Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted January 15, 2014 Report Share Posted January 15, 2014 Let it warm up with the coolant reservoir cap off with the heat full blast, watch the coolant level and at some point a large "burp" of bubbling air should work its way out, some times quickly sometimes not so much spilling some over. Have replacement coolant at the ready. The next day or when the car fully cools off recheck the level and top off as needed. Quote Link to comment Share on other sites More sharing options...
The Bone Posted January 18, 2014 Report Share Posted January 18, 2014 If you haven,t done anything to the cooling system than don't try to burp the system. It doesn't need it. It may be something as simple as a vacuum hose your dealer should be able to fix it. It also may be because you have the system set to auto and the sensor on the dash senses heat and turns on the air.. The HVAC system in our cars are very complex and I had to read the book to figure out what was happening. Good luck Quote Link to comment Share on other sites More sharing options...
Port139 Posted February 28, 2014 Report Share Posted February 28, 2014 Has anyone with this cold air at idle issue found a solution. Has burping the system worked. I would like to hear from anyone who has rectified this problem and the solution they implemented? Quote Link to comment Share on other sites More sharing options...
tss Posted February 28, 2014 Report Share Posted February 28, 2014 ecoboostperformance.com - check it out - infinitely more likely to get an answer over there. Quote Link to comment Share on other sites More sharing options...
SHOdded Posted February 28, 2014 Report Share Posted February 28, 2014 Have you checked your coolant levels? If the reservoir seems to be the correct level, I'd still try adding a quart of coolant at a time, drive the car with the heat on for a bit, check it again. Repeat till heat works properly again, keeping an eye on the reservoir levels. All levels checked after engine has cooled down. This has worked for some folks as an alternative to "burping". Quote Link to comment Share on other sites More sharing options...
Port139 Posted February 28, 2014 Report Share Posted February 28, 2014 Yes. I have checked the Coolant level. The first step I did to attempt a fix to take it to my dealer who as a first step replaced the thermostat and gasket. That didn't work and was told that engine was burped and coolant topped at that time. I not leaking coolant. Since the heat is only cut off when car is idling at 500 rpm but will blow hot air at 600 rpm and over I logically think this is some sort of vent gate that is loose or malfunctioning. Thanks for replying back. I will still try what you all are recommending. Quote Link to comment Share on other sites More sharing options...
Port139 Posted March 20, 2014 Report Share Posted March 20, 2014 Took my car into dealer. They reprogrammed it and now it works fine. I also noticed my car now idles at 600rpm rather than 500rpm. I don't have the exact details but know its really fixed and I have heat at idle. Quote Link to comment Share on other sites More sharing options...
SHOdded Posted March 20, 2014 Report Share Posted March 20, 2014 Good to know, glad it worked for you! I think this is the first fix by reprogramming for "no heat at idle" that I have seen. Quote Link to comment Share on other sites More sharing options...
