ksspeed Posted January 14, 2014 Report Share Posted January 14, 2014 About 6 months ago I was headed to see a buddy in Arizona leaving Kansas and it started to rain the biggest raindrops I had ever seen (I mention this because of issues reported with cars stalling in humidity or moisture somewhere after the intake). My car lost all power so I headed home. It ran like it was missing on a few cylinders only it smoked. It continued smoking even for several seconds after turning the car off. Turning the car on was very difficult. It smelled and seemed like the car was flooded. On the way home my car consumed about 4X the normal fuel rate. The dealer said my injector melted. She drove real doggy after that so a few months later I took it back into the dealership while the light was still on and they replaced a catalytic converter clogged with plastic from the melted injector. She drove better but still doggy and the engine light came on and stayed on for a few miles so I took her back to the same dealership and they replaced the second cat which was clogged with plastic from the melted injector. I just took her back for running doggy and they said a few of the spark plugs had a ceramic failure that caused the inside ceramic piece to basically float around in there. She still isn't running right and I'm sure I have plastic from the injector in more of my car. Everywhere from the cylinder to the turbo impellers to the exhaust pipes, down pipe, mufflers and most likely back into my injectors. My only modification to the car is an Airaid intake. I've been to 3 different dealerships to fix the issue and the most recent dealership didn't understand how plastic could get into my cats since the injector couldn't melt. He thought the plastic magically appeared from raw fuel being sent to my cat after a HOSE delivering fuel to my injector melted. He didn't understand that the plastic made it through my engine into my cats. I do not have documentation on if it was plastic that melted or if it was the injector that melted; however, the original dealership told me the injector melted due to a leak in the fuel system. The lead mechanic at the 2nd dealerships had some harsh words to say about the 1st dealership not fixing the car right when they replaced the first cat. He had some harsh words to say about his own shop after I took the car back in and they had to replace the 2nd cat. When I took the car in for them to replace the 2nd cat he told me I was getting all new exhaust from the 2nd cat back. When I went to pick the car up the service department manager told me they only replaced the 2nd cat and couldn't replace the exhaust because they couldn't prove there was plastic in there. He said they didn't have a "scope" that would let them see inside the exhaust and Ford wouldn't let them replace parts just because someone thinks are broken. Their head mechanic disappeared once I started to complain. Here's my issue. I thought everything would be sorted out about 20,000 miles before now. My CPO warranty runs out at 100,000 miles. Today the car has 97,980 miles and will have 98,500 by Thursday when I return home so I need to find a way to actually resolve this issue now. Is there a department at Ford I can talk to that will actually take the time and care enough to listen? If not can anyone tell me what steps to take? Quote Link to comment Share on other sites More sharing options...
SHOdded Posted January 15, 2014 Report Share Posted January 15, 2014 First off, sorry to hear about your experience, pretty awful. Second, you should talk to Lincoln Customer Service, not Ford. Guaranteed better treatment by Lincoln. I assume the CPO warranty is Ford/Lincoln issued? Hopefully you had the car serviced at Ford/Lincoln dealerships only. You will also get more responses over at http://www.ecoboostperformanceforum.com. This forum is very, very quiet for the most part. BTW, if you can avoid driving the car before you talk to Lincoln, by all means do so. Quote Link to comment Share on other sites More sharing options...
ksspeed Posted January 17, 2014 Author Report Share Posted January 17, 2014 I have only been speaking to someone in the warranty department from the number on my CPO warranty. I would guess it's Ford/Lincoln issued. Unfortunately I have traveled a lot this year and only 1 of my oil changes have been done by Ford/Lincoln if even 1 of them. I'll post on the other site. Quote Link to comment Share on other sites More sharing options...
SHOdded Posted January 17, 2014 Report Share Posted January 17, 2014 If you bought the MKS from a Ford/Lincoln dealership, your CPO should be fine. But if people at the provided number do not respond to your satisfaction, may be worth calling Lincoln Customer Service directly for assistance and referencing your previous interaction. That way, you KNOW who you are talking to. Can make a significant difference in the end results. See you on the other site Quote Link to comment Share on other sites More sharing options...
ksspeed Posted January 17, 2014 Author Report Share Posted January 17, 2014 I did buy the MKS from a Lincoln dealer. Just called Lincoln customer service and the lady was very nice. Let's hope it leads to getting my issues resolved. Thank you for the help ppl. Quote Link to comment Share on other sites More sharing options...
gdavenport Posted August 1, 2014 Report Share Posted August 1, 2014 it would be extra special if there were pictures of this melted fuel injector. Do you have something that would show the metal chassis with little/no plastic left on it? Did the dealer tech explain how it's possible that the injector melted? Only one injector melted? Which cats were affected? Quote Link to comment Share on other sites More sharing options...
BBOX Posted August 2, 2014 Report Share Posted August 2, 2014 it would be extra special if there were pictures of this melted fuel injector. Do you have something that would show the metal chassis with little/no plastic left on it? Did the dealer tech explain how it's possible that the injector melted? Only one injector melted? Which cats were affected? Post is eight months old dude. Quote Link to comment Share on other sites More sharing options...
