bigPelo Posted September 5, 2012 Report Share Posted September 5, 2012 Has anyone had luck displaying the outdoor temperature on their 2013 SHO? It's supposed to be a standard feature but I can't find it Quote Link to comment Share on other sites More sharing options...
goblues38 Posted September 5, 2012 Report Share Posted September 5, 2012 On the display bottom on the right of the speedo. Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 5, 2012 Author Report Share Posted September 5, 2012 This is an image I found on google that is showing it clearly: But I doesn't display in my car... I need to take a look at the owners manual maybe... :doh: Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 5, 2012 Report Share Posted September 5, 2012 I wanted/expected to see it on the main screen but its to the right of the speedo lower left corner. At least its there, I was pretty pissed when I thought it was not a feature. Other note, I can't get the auto wipers working. It was pouring here today and no matter what I set they never adjusted speed to accomodate the water. Going to get the owners manual out because its an installed option for me!! Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 5, 2012 Author Report Share Posted September 5, 2012 Well outdoor temp now displaying in •C. Auto wipers not working as well... Keep posted if you find out how to set them properly. Quote Link to comment Share on other sites More sharing options...
TractorAK Posted September 6, 2012 Report Share Posted September 6, 2012 Is it the setup within the left side steering wheel menu? Mine was on when bought it. Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 6, 2012 Report Share Posted September 6, 2012 I got mine working. My previous experience with this type of feature was my Trailblazer SS which was very sensitive. Click the wipers onto the first delayed line this is the lowest sensitivity. I found that for the light rain today on the 2nd line was a good setting. I also shut off the rain sensing from the menu and then turned it back on. It didn't rain heavily today but the wipers did work. I think having a tint strip on the front might also slightly affect the sensitivity of this feature. Quote Link to comment Share on other sites More sharing options...
Smokeio Posted September 15, 2012 Report Share Posted September 15, 2012 Go into settings, clock, display outdoor temp to yes. This will now show your temp on main display. Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 16, 2012 Report Share Posted September 16, 2012 Go into settings' date=' clock, display outdoor temp to yes. This will now show your temp on main display.[/quote'] This didnt work on my '13. There is no display outdoor temp anywhere in the clock or any settings tab. Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 18, 2012 Report Share Posted September 18, 2012 I just updated Sync to 3.2.2 and its automatically next to the clock on the main display. Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 18, 2012 Report Share Posted September 18, 2012 I just updated Sync to 3.2.2 and its automatically next to the clock on the main display. Same here. Just run the update on the "sync my ride" website Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 18, 2012 Report Share Posted September 18, 2012 This upgrade is a disaster! I ran it and it said successful, then it updated on syncmyride off the log file on the usb drive. It Showed under my vehicle 3.2.2, now it shows 3.02 shows upgrade available. Under my sync download history it shows 3.2.2 update, then last entry is 3.02 and its says if you have a navigation SD Card DO NOT PERFORM 3.2.2 Update as Ford will be mailing me an SD card with the update, new nav points, and faster interface upgrade. The sync forums have a ton of posts about this. So I do know that I have the external tempature, but I lost all my saved stations and nav points and probably have a botched install. Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 18, 2012 Report Share Posted September 18, 2012 This upgrade is a disaster! I ran it and it said successful' date=' then it updated on syncmyride off the log file on the usb drive. It Showed under my vehicle 3.2.2, now it shows 3.02 shows upgrade available. Under my sync download history it shows 3.2.2 update, then last entry is 3.02 and its says if you have a navigation SD Card DO NOT PERFORM 3.2.2 Update as Ford will be mailing me an SD card with the update, new nav points, and faster interface upgrade. The sync forums have a ton of posts about this. So I do know that I have the external tempature, but I lost all my saved stations and nav points and probably have a botched install.[/quote'] Seemed to work fine for me. The update will certainly wipe your presets, but that's a normal part of the process. Quote Link to comment Share on other sites More sharing options...
goblues38 Posted September 19, 2012 Report Share Posted September 19, 2012 did the update with no issues. Not that big of deal to redo satalite pre sets. FM and AM did not reset. All my nav destinations were kept. had to resync my iPhone. Thought that was odd. Quote Link to comment Share on other sites More sharing options...
