stixx2002 Posted September 12, 2012 Report Share Posted September 12, 2012 Just ordered the Livernois tune yesterday, and it looks like it should be on my doorstep today. From what I have seen, it appears I have to connect the device to the car, extract a code and send it to Livernois via email. I would assume they then send me a file that I upload to the device. Hopefully I will be ready for a test drive by the weekend. Will report back with progress..... Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 12, 2012 Report Share Posted September 12, 2012 Just ordered too! Let me know how it goes for you. Can't wait to try it :car: Quote Link to comment Share on other sites More sharing options...
tss Posted September 12, 2012 Report Share Posted September 12, 2012 Just ordered the Livernois tune yesterday, and it looks like it should be on my doorstep today. From what I have seen, it appears I have to connect the device to the car, extract a code and send it to Livernois via email. I would assume they then send me a file that I upload to the device. Hopefully I will be ready for a test drive by the weekend. Will report back with progress..... That's the procedure, though I just drove mine down there and had Rick do it..... You are going to love it. Remember, with push button start, when you are prompted to turn the car to the on position, press and hold the start button for about 10 seconds (do NOT press the brake while doing this). Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 14, 2012 Author Report Share Posted September 14, 2012 Well here's something weird. The programmer never seems to finish. It seems to upload the tune fine, then it asks me to turn the ignition off, then hit the "Y" button, then turn the car to "on" and hit the "y" button, then it programs the car again. IT will just do this over and over. Maybe I just need to unplug it after it asks me to turn the ignition off, but I would have assumed to have a screen state "disconnect programmer" or something to that effect. Quote Link to comment Share on other sites More sharing options...
tss Posted September 14, 2012 Report Share Posted September 14, 2012 I get a message to that effect. Something like program has loaded successfully...... Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 14, 2012 Author Report Share Posted September 14, 2012 So strange. As the tune is uploading my windshield wipers turn on and the front defrosters as well. Crazy Quote Link to comment Share on other sites More sharing options...
tss Posted September 14, 2012 Report Share Posted September 14, 2012 I make sure radio and climate are turned to off before loading anything. Are the wipers in "Off" position or on the rain sensing feature (which looks like intermittent)? Double check that. Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 14, 2012 Author Report Share Posted September 14, 2012 I make sure radio and climate are turned to off before loading anything. Are the wipers in "Off" position or on the rain sensing feature (which looks like intermittent)? Double check that. Yep - everything was off. During the tune process wipers and defrosters turned on by themselves. Also, my Sync system completely reboot/reset. Not a very pleasant and successful process. For $600, I would have hoped the bugs were worked out. Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 14, 2012 Report Share Posted September 14, 2012 Still not working? Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 14, 2012 Author Report Share Posted September 14, 2012 Still not working? Nope - Livernois is looking into it Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 14, 2012 Author Report Share Posted September 14, 2012 So apparently the wipers, defroster and Sync reset is a normal part of the process. However, per Livernois, there should definitely be a programming complete" type of message that I am not receiving. Hopefully gets resolved today Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 14, 2012 Report Share Posted September 14, 2012 What tuner are Livernois using? Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 14, 2012 Author Report Share Posted September 14, 2012 What tuner are Livernois using? looks like AIW Quote Link to comment Share on other sites More sharing options...
darreli Posted September 14, 2012 Report Share Posted September 14, 2012 They use SCT or MyCal which is AIW on a DashDAQ Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 14, 2012 Report Share Posted September 14, 2012 Hey I am still having the same issues. I returned mine to stock this morning, and when I went to reprogram it I got 18 DCT errors, and an error 6B unresponsive computer. I eventually got the 93 PERF tune back on successfully. There is an issue they are working on. All I can tell you is what I did: Open door, hit button once, hit second time holding it down for 10 seconds. Make sure radio, climate, auto lights and wipers are turned off. Install the tune, it will go to 100% then tell you turn off ignition, turn on ignition. Then it will write again to 50% and prompt again to turn off/turn on. If it fails let it reprogram back to stock, shut everything off and open the door, then close the door and try again. Its a pain, but it will load eventually and they will figure it out. Good luck. Oh and you want to get it on the car because the change is significant! Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 14, 2012 Author Report Share Posted September 14, 2012 Hey I am still having the same issues. I returned mine to stock this morning, and when I went to reprogram it I got 18 DCT errors, and an error 6B unresponsive computer. I eventually got the 93 PERF tune back on successfully. There is an issue they are working on. All I can tell you is what I did: Open door, hit button once, hit second time holding it down for 10 seconds. Make sure radio, climate, auto lights and wipers are turned off. Install the tune, it will go to 100% then tell you turn off ignition, turn on ignition. Then it will write again to 50% and prompt again to turn off/turn on. If it fails let it reprogram back to stock, shut everything off and open the door, then close the door and try again. Its a pain, but it will load eventually and they will figure it out. Good luck. Oh and you want to get it on the car because the change is significant! Did Livernois provide you with this procedure (door open, door close, etc) or did you somehow figure this out on your own? Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 14, 2012 Report Share Posted September 14, 2012 I think the wind was blowing in the right direction and the stars were in alignment. Rick was working on my issue since this morning but since I got the tune loaded back on I'm not going to keep bugging them I know he will get it right for us. Quote Link to comment Share on other sites More sharing options...
74d34h Posted September 14, 2012 Report Share Posted September 14, 2012 Oh btw one other thing I noticed for my successful tunes the blind spot indicator is lit up on both sides during the writing phase, and I get a blind spot error message on the left display when its complete. I do not get any of this when its not successful! Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 14, 2012 Report Share Posted September 14, 2012 I will need to print these posts and bring them with the tuner in the car when I get it. Thanks for the feed back! Quote Link to comment Share on other sites More sharing options...
Paulford8 Posted September 16, 2012 Report Share Posted September 16, 2012 Dont fret! Some of the ECMs have "quirks" for lack of a better term that make tuning more difficult. My SHO went pretty smooth, but when I did I Mustang I ended up leaving it with a tuner. He was on and off the phone with SCT all day before he could get it to update. Be patient the guys at Livernois will figure out it! Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 18, 2012 Report Share Posted September 18, 2012 How do you turn ignition OFF when in accessory mode or ON mode? Only way I find was opening the driver door... Quote Link to comment Share on other sites More sharing options...
stixx2002 Posted September 18, 2012 Author Report Share Posted September 18, 2012 How do you turn ignition OFF when in accessory mode or ON mode? Only way I find was opening the driver door... I simply cycle through the start button. One press is accessory; two is on; the third shuts me down Quote Link to comment Share on other sites More sharing options...
bigPelo Posted September 18, 2012 Report Share Posted September 18, 2012 Didn't seem to work at lunch time while extracting the strategy code. Probably an operator error. The important part is I have the code and LMS as an e-mail Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
