Ram Air setup
Here is my homemade ram air set up. Used to sections of 3" Spectre flexible intake pipe. Cut some slits on the bottom of the bottom section to let any water that would happen to get in a way out. First driving impression seem very positive. I had to make couple of stops, so car got some heat soak, car still responded the same. Everything is easily removed if I don't like the result, but in theory it should work, car is getting air from another source.
http://s1290.photobucket.com/user/bamkmm91/library/SHO%20ram%20air%20setup?sort=3&page=1
