Flak Posted November 5, 2012 Report Share Posted November 5, 2012 I finally dumped the *amazing* goodyear supercars /sarcasm I went up to 255/45/20. I'm currently using torrie's tune (awesome sauce) and was wondering if I can just use the SCT to change the rotations to 713. Or will I have to get torrie to change it for me? If I can just use the SCT to change it to 713, do I have to then reflash the tune? Thanks Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted November 5, 2012 Report Share Posted November 5, 2012 Although I no longer have my SCT tuning device, upon recollection, I think there was a subsection that allows you to customize, and/or change the aspects of any particular tune file. One of which was tire size. I think anytime you change a parameter of the tune, in order for it to successfully work , you would then need to reflash it after said change. I would contact the company who developed your file for further advice / clarification and proceed from there :thumb: How are the new tires working out btw? Quote Link to comment Share on other sites More sharing options...
darreli Posted November 5, 2012 Report Share Posted November 5, 2012 You can adjust for tires on the SCT to a certain extent...in your case you should be fine. Yes you would flash it again...it should ask you prior to loading a custom tune if you want to make adjustments..revs per mile are in that Quote Link to comment Share on other sites More sharing options...
Flak Posted November 8, 2012 Author Report Share Posted November 8, 2012 Cool, thanks. I went with the Yokohama Parada Spec-X. Compared to the Goodyears, these tires are from the future. Ultra quiet on the road, handling seems better and the ride isn't as bouncy (has the PP). We'll see how they do in the winter, I usually rotate summer/winter so hopefully I don't kill myself or someone else this year. Quote Link to comment Share on other sites More sharing options...
Franchi Posted November 9, 2012 Report Share Posted November 9, 2012 Long as whoever wrote your custom tune didn't lock it out, you should be able to adjust that yourself no problem. Quote Link to comment Share on other sites More sharing options...
SHOdded Posted November 9, 2012 Report Share Posted November 9, 2012 Seems like these Yoko's only complaint is treadlife (tirerack.com). Weather is no problem. Another good tire mfr! Quote Link to comment Share on other sites More sharing options...
