mhenne4 Posted November 7, 2012 Report Share Posted November 7, 2012 So Im trying to hard wire my radar. I cant figure out what fuse to add the tap to. Anyone able to tell me which fuse to add the tap to? Quote Link to comment Share on other sites More sharing options...
mhenne4 Posted November 8, 2012 Author Report Share Posted November 8, 2012 Fuse 33 is the one we need. Quote Link to comment Share on other sites More sharing options...
EcoBoostSHO Posted November 8, 2012 Report Share Posted November 8, 2012 Yep. That's where mine is! Quote Link to comment Share on other sites More sharing options...
Lesterg69 Posted November 8, 2012 Report Share Posted November 8, 2012 I have mine mounted above the mirror on left side and was able to tap into sunroof switches. Quote Link to comment Share on other sites More sharing options...
local17bri Posted November 8, 2012 Report Share Posted November 8, 2012 I have mine mounted above the mirror on left side and was able to tap into sunroof switches. Same here. The only downside is that the radar detector turns on whenever the the doors are unlocked and dome light is activated or when the power accessories are on with the ignition off. It also turns on if I open the trunk with the key fob or the button on the bumper, but goes back to sleep after a minute. I would have preferred it to come on only with the ignition on, but its not a big deal. Quote Link to comment Share on other sites More sharing options...
Lesterg69 Posted November 9, 2012 Report Share Posted November 9, 2012 You must have it wired to dome lights, remove that find the wires for the sunroof switch which is key on only. Quote Link to comment Share on other sites More sharing options...
local17bri Posted November 9, 2012 Report Share Posted November 9, 2012 You must have it wired to dome lights' date=' remove that find the wires for the sunroof switch which is key on only.[/quote'] You're right, I did have it wired to the dome light. I just switched it over from the yellow wire on the dome light block to the violet wire on the sunroof wire block and it works perfectly. Thanks. Quote Link to comment Share on other sites More sharing options...
