10SECSHO Posted November 25, 2012 Report Share Posted November 25, 2012 Did a tire rotation about month ago and yesterday got the low tire pressure warning light. Checked all tires and one was 25 psi. Put air in it and brought all 4 up to 32 psi. Do I need reset tool for the tpms sensors? Have not driven the car since the light came on. Will reset itself or do I buy a reset tool or let ford do it? Quote Link to comment Share on other sites More sharing options...
Lesterg69 Posted November 25, 2012 Report Share Posted November 25, 2012 Will reset after driving about 10 miles Quote Link to comment Share on other sites More sharing options...
10SECSHO Posted November 25, 2012 Author Report Share Posted November 25, 2012 Thanks...... Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted November 26, 2012 Report Share Posted November 26, 2012 You shouldn't need to go anywhere close to 10 miles, unless you drive really slowly. Mine update after only a couple blocks. According to the factory service manual, "The SJB monitors the air pressure in the 4 road tires with tire pressure sensors. The sensors transmit radio frequency signals to the SJB approximately every 60 seconds when the vehicle speed exceeds 32 km/h (20 mph)." -Rod Quote Link to comment Share on other sites More sharing options...
swetrid Posted November 26, 2012 Report Share Posted November 26, 2012 It should go out once you reach 20 mph or so and it sat for awhile it will go out on startup when the sensors wake up. Quote Link to comment Share on other sites More sharing options...
10SECSHO Posted November 26, 2012 Author Report Share Posted November 26, 2012 Yep warning went away. Thanks again. Quote Link to comment Share on other sites More sharing options...
nameneeded Posted November 28, 2012 Report Share Posted November 28, 2012 Just out of curiosity... are the sensors in the hubs (rotation style), in the valve stems or in the rims. I'm going to need some winter rims and need to know is I will need TPS as well. Thx! Quote Link to comment Share on other sites More sharing options...
Crash712us Posted November 29, 2012 Report Share Posted November 29, 2012 Just out of curiosity... are the sensors in the hubs (rotation style), in the valve stems or in the rims. I'm going to need some winter rims and need to know is I will need TPS as well. Thx! On your 2013 there apart of the valve stem. Quote Link to comment Share on other sites More sharing options...
