BIGFOOT Posted December 7, 2012 Report Share Posted December 7, 2012 so from searching, it seems as if the 10-12 SHO has a +38 offset stock....? and the hub/bolt pattern are typical ford the same as the mustang. heres the wheels im looking at, will they jive? #1 http://www.americanmuscle.com/gunmetal-nurburing-20x8-0512.html #2 http://www.americanmuscle.com/machined-mugello-20x85-0513.html #3 well we will start with those.... teach me. Quote Link to comment Share on other sites More sharing options...
BIGFOOT Posted December 7, 2012 Author Report Share Posted December 7, 2012 ok here is #3 http://www.americanmuscle.com/graphite-bravadoamericana-20x95-0512.html Quote Link to comment Share on other sites More sharing options...
racerx78 Posted December 7, 2012 Report Share Posted December 7, 2012 I'll refer to my previous post on wheel fitment I'd use the the fitment calculator at Rim-N-Tires its about the best one i've see out there for finding what fits. I believe the OEM wheel size is 20x8 5x114.3 39mm offset. Quote Link to comment Share on other sites More sharing options...
JoeB Posted December 7, 2012 Report Share Posted December 7, 2012 First 2 will fit no problem. I think bpd runs the first ones, look in here for his post and check what sizes he's running. Not sure about the 3rd ones with being 9.5" and a +45 offset, check that calculator above and see what it says. Quote Link to comment Share on other sites More sharing options...
nameneeded Posted December 7, 2012 Report Share Posted December 7, 2012 This is the calculator I like. It makes things easy. Same one RacerX recommended. It tells you everything! http://www.rimsntires.com/specs.jsp Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted December 7, 2012 Report Share Posted December 7, 2012 I can certainly make a sticky thread of different rim/tire size calculators if we get enough of a collection of them to warrant doing so. The stock offset, for the 2010-2012 model years, is indeed 38. The bolt pattern is 5x114.3 For the 20" upgraded wheel pkg from FMC, those are 20x8's all around. As far as I am aware, I am the only one currently running a staggered set up on the AWD platform. My rim sizes are: Up front, 20x8.5's and the rears are 20x10. Both at a 40mm offset. I would suspect you may run into issues running 20x9.5's up front. Unfortunately, the person who was instrumental in assisting with my rim/tire combo has chosen to no longer participate here on EBOF. Too bad really, cuz he offered a wealth of information. Sent from my DROID3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
homer Posted December 7, 2012 Report Share Posted December 7, 2012 i can tell you that the hub size on the sho is smaller than the mustang. I was going to run the wheels off my mustang on the sho for winter and the sho wheels did not appear to clear the hubs Quote Link to comment Share on other sites More sharing options...
FLIP-4-SHO Posted December 7, 2012 Report Share Posted December 7, 2012 I can certainly make a sticky thread of different rim/tire size calculators if we get enough of a collection of them to warrant doing so. The stock offset, for the 2010-2012 model years, is indeed 38. The bolt pattern is 5x114.3 For the 20" upgraded wheel pkg from FMC, those are 20x8's all around. As far as I am aware, I am the only one currently running a staggered set up on the AWD platform. My rim sizes are: Up front, 20x8.5's and the rears are 20x10. Both at a 40mm offset. I would suspect you may run into issues running 20x9.5's up front. Unfortunately, the person who was instrumental in assisting with my rim/tire combo has chosen to no longer participate here on EBOF. Too bad really, cuz he offered a wealth of information. Sent from my DROID3 using Tapatalk 2 Please give the Tire info for your staggered setup as well Please. Thanks. Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted December 7, 2012 Report Share Posted December 7, 2012 Please give the Tire info for your staggered setup as well Please. Thanks. Oh yea, oops :doh: Here 'ya go: Fronts are: 255/45 ZR20 Rears are: 275/40 ZR20 Sent from my DROID3 using Tapatalk 2 FLIP-4-SHO 1 Quote Link to comment Share on other sites More sharing options...
racerx78 Posted December 7, 2012 Report Share Posted December 7, 2012 i can tell you that the hub size on the sho is smaller than the mustang. I was going to run the wheels off my mustang on the sho for winter and the sho wheels did not appear to clear the hubs Is the difference to much that you can't run centric hub rings to keep everything balanced correctly like wheel shops do for most aftermarket wheels. [ATTACH=CONFIG]1415[/ATTACH] Quote Link to comment Share on other sites More sharing options...
nameneeded Posted December 8, 2012 Report Share Posted December 8, 2012 I can certainly make a sticky thread of different rim/tire size calculators if we get enough of a collection of them to warrant doing so. Stock SHO wheels are 20x8 5x114.5 (5x4.5) 39 offset. Various tire calculators. If these won't do it then you are...... http://www.rimsntires.com/specs.jsp http://www.1010tires.com/tiresizecalculator.asp http://www.miata.net/garage/tirecalc.html http://www.gordon-glasgow.org/tirecalc.html http://kgm.tiwing.com/calcs/tiresizecalc.htm http://www.discounttiredirect.com/direct/brochure/info/tmpInfoTireMath.jsp Quote Link to comment Share on other sites More sharing options...
BIGFOOT Posted December 8, 2012 Author Report Share Posted December 8, 2012 so ive been messing with the tire/wheel calculator, but how do i know how to interpret the findings? what are the measurements i need to stay within? Quote Link to comment Share on other sites More sharing options...
JoeB Posted December 8, 2012 Report Share Posted December 8, 2012 so ive been messing with the tire/wheel calculator' date=' but how do i know how to interpret the findings? what are the measurements i need to stay within?[/quote'] Use the rimsntires.com calculator. Try to keep the tire circumference as close as possible (rule of thumb is under 3% difference) then at the bottom there will be measurements as to how much farther it will stick out, how close it is to your brakes, etc. As long as you have the extra room mentioned, the rims should fit. And make sure you have enough room with the wheel turned all the way so they won't rub. Quote Link to comment Share on other sites More sharing options...
homer Posted December 8, 2012 Report Share Posted December 8, 2012 The mustang wheels fit on the sho, and the lug nuts centered the wheel... I just put one on to test... However, the sho wheel would not go on the mustang Quote Link to comment Share on other sites More sharing options...
BIGFOOT Posted December 8, 2012 Author Report Share Posted December 8, 2012 Thanks for the new sticky!!!! Quote Link to comment Share on other sites More sharing options...
