ejjp13 Posted March 7, 2013 Report Share Posted March 7, 2013 Is there any benifit of replacing the 2 bar with the 3 bar if I do not plan on installing the Meth kit? Quote Link to comment Share on other sites More sharing options...
turbodave Posted March 7, 2013 Report Share Posted March 7, 2013 Not really. The 3 bar just allows you to read boost levels higher that 15psi. Now, if you have thoughts of running boost higher than 15psi, then you'll need to replace them both I would assume. The computer needs to know what level it's at as importantly as you do. Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted March 8, 2013 Report Share Posted March 8, 2013 You won't need to replace both. Only the sensor POST throttle body will require replacement. Additionally, I believe the magic number is actually 14.2 or 14.3lbs before the 2bar MapV no longer reads it properly. You'll definitely need the 3bar if you exceed those psi ranges. Sent from my DROID3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Slowsho Posted March 9, 2013 Report Share Posted March 9, 2013 Is it a Bosch 3 bar map sensor? And anyone know where I can buy one separately then buying the meth kit? Quote Link to comment Share on other sites More sharing options...
Crash712us Posted March 9, 2013 Report Share Posted March 9, 2013 comes with meth kit from LMS, unleashed tuning sells separately and more than likely LMS does as well. Car has to be tuned for it though. Quote Link to comment Share on other sites More sharing options...
Slowsho Posted March 9, 2013 Report Share Posted March 9, 2013 Well would the stage 5 tune be considered tuned for it? Quote Link to comment Share on other sites More sharing options...
Crash712us Posted March 9, 2013 Report Share Posted March 9, 2013 Why yes it would. Quote Link to comment Share on other sites More sharing options...
oknighttrain Posted March 9, 2013 Report Share Posted March 9, 2013 Does anyone have a part number for the 3 bar map sensor? Quote Link to comment Share on other sites More sharing options...
Crash712us Posted March 9, 2013 Report Share Posted March 9, 2013 Here you go[ATTACH]2064[/ATTACH] Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted March 10, 2013 Report Share Posted March 10, 2013 Not really. The 3 bar just allows you to read boost levels higher that 15psi. Now' date=' if you have thoughts of running boost higher than 15psi, then you'll need to replace them both I would assume. The computer needs to know what level it's at as importantly as you do.[/quote'] You won't need to replace both. Only the sensor POST throttle body will require replacement. Additionally, I believe the magic number is actually 14.2 or 14.3lbs before the 2bar MapV no longer reads it properly. You'll definitely need the 3bar if you exceed those psi ranges. Sent from my DROID3 using Tapatalk 2 So if I am reading 15psi on a "physical" gauge, do I need to go to a 3 bar sensor if the 2 bar sensor doesn't send proper readings to the computer when it is over 14.3psi? Most of the time it is lower, just full throttle acceleration puts the needle at 15 psi. Quote Link to comment Share on other sites More sharing options...
Crash712us Posted March 10, 2013 Report Share Posted March 10, 2013 So if I am reading 15psi on a "physical" gauge, do I need to go to a 3 bar sensor if the 2 bar sensor doesn't send proper readings to the computer when it is over 14.3psi? Most of the time it is lower, just full throttle acceleration puts the needle at 15 psi. No not need for you, only needed with stage 5 meth tune. Changing to a bar 3 without it being tuned for will will throw and trouble light and run car will run poorly. Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted March 10, 2013 Report Share Posted March 10, 2013 I was figuring that it was not needed in my case, especially since many people are running LMS tunes with the 2 bar sensors, but just wanted to be sure. If I did get the 3 bar, I would also get the new tune from Rick to maintain driveability. Quote Link to comment Share on other sites More sharing options...
Crash712us Posted March 10, 2013 Report Share Posted March 10, 2013 Hmmm then my guess is LMS or unleashed tuning are modifying to make it bar 3, much like the 170 degree T-stat. Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted March 10, 2013 Report Share Posted March 10, 2013 This had me curious, so I went and dug up the box that my 3 bar MapV sensor arrived in (along with my meth kit) and it appears to be the same as what crash712us had previously posted. Perhaps LMS is modifying them 2 bar sensors as Chris eluded to, or perhaps they just shipped the 3 bar's in the wrong box? :noidea: Probably a question better left answered to the expert(s)..... like Rick over @ LMS. Quote Link to comment Share on other sites More sharing options...
