RamblinClam Posted May 11, 2013 Report Share Posted May 11, 2013 Does anyone else have a sun roof that squeaks and creaks while you're driving? Now that the warm weather is here, mine is making quite the racket. It just started and It's killing me. Quote Link to comment Share on other sites More sharing options...
geswek Posted May 11, 2013 Report Share Posted May 11, 2013 Mm; my car is a few days old and I've not heard anything yet. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted May 11, 2013 Report Share Posted May 11, 2013 Never had any noise from mine. Quote Link to comment Share on other sites More sharing options...
RamblinClam Posted May 13, 2013 Author Report Share Posted May 13, 2013 As it turns out, it was the head liner making all that noise. I just pulled it down and it's no longer rubbing on anything. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted May 13, 2013 Report Share Posted May 13, 2013 Glad to hear it was an easy fix...some others have posted about the wiring harness in the headliner making noise...I believe on the passenger side. Quote Link to comment Share on other sites More sharing options...
markssho Posted May 13, 2013 Report Share Posted May 13, 2013 I had the hiring harness rattling right above the passenger. A small foam block wedged between the wires and headliner, fixed the issue. Quote Link to comment Share on other sites More sharing options...
RamblinClam Posted May 13, 2013 Author Report Share Posted May 13, 2013 I had the hiring harness rattling right above the passenger. A small foam block wedged between the wires and headliner, fixed the issue.Good to know about the wiring for future reference. Quote Link to comment Share on other sites More sharing options...
NAiLs Posted May 15, 2013 Report Share Posted May 15, 2013 I notice mine rattling around only when the headliner for the sunroof is pulled back. I also have a very annoying rattle in the map lights, which disappears when I put a little pressure on the passenger side. I think the rain sensor camera box rattles slightly, too. Ugh! I'm not too thrilled with all of these rattles on a 2 year old car, when my G8 @ 5 years old doesn't make a single noise... and the interior isn't as nice as the SHO. Quote Link to comment Share on other sites More sharing options...
markssho Posted May 16, 2013 Report Share Posted May 16, 2013 There is a heat shield in the map light that is probably rattling. If someone replaced the bulb and didn't put the heat shield back correctly, it will rattle. Open it and replace it and that will probably fix the map light rattle. Quote Link to comment Share on other sites More sharing options...
NAiLs Posted May 16, 2013 Report Share Posted May 16, 2013 There is a heat shield in the map light that is probably rattling. If someone replaced the bulb and didn't put the heat shield back correctly' date=' it will rattle. Open it and replace it and that will probably fix the map light rattle.[/quote']Thanks for the tip! I'll look at that when I decide to plunge on some LED's. Quote Link to comment Share on other sites More sharing options...
