2011 SHO Driver Posted June 24, 2013 Report Share Posted June 24, 2013 I just took a 1700 mile road trip in my 2011 SHO, and since I've owned the car for about 2 months, havent really used the A/C Not sure if its because of it being a black car , but it just doesnt seem that my A/C blows as cold as it should ? I bought the car used with 37k miles so the warranty is no longer an option, but curious if anyone else has a less than cold A/C ? Thanks Quote Link to comment Share on other sites More sharing options...
83racecrew Posted June 24, 2013 Report Share Posted June 24, 2013 IMO we haven't had cold A/C since r134a came about. That said, how hot was it outside when you particularly noticed the "not so cold"? Quote Link to comment Share on other sites More sharing options...
2011 SHO Driver Posted June 24, 2013 Author Report Share Posted June 24, 2013 Pretty hot, probably around 90 or so, but what i noticed most was when i would put the heavy foot down, i lost what cold air was blowing for a couple of minutes, almost like it was catching up with itself ? I havent put a temp gauge on it to see what temp is actually blowing from the vents, but its definately not as cold as it should be. I will most likely take it in and have someone check it, but just curious if maybe the A/C's on these cars aren't as good as they should be ? Quote Link to comment Share on other sites More sharing options...
Crash712us Posted June 25, 2013 Report Share Posted June 25, 2013 under hard accelerate the A/C shuts down. 1st thing I'd check is the cabin filter. If you search the forum I know there is a how to on this. Quote Link to comment Share on other sites More sharing options...
HighBarSHO Posted June 25, 2013 Report Share Posted June 25, 2013 You have cabin filter and the a/c seats both have filters. Check and see if the cabin filter is dirty. I was in 93 degree weather and mine works well especially with the a/c seats blowing cold air on my balz. Quote Link to comment Share on other sites More sharing options...
2011 SHO Driver Posted June 25, 2013 Author Report Share Posted June 25, 2013 I will check the filter this weekend...thanks for the information . Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted June 25, 2013 Report Share Posted June 25, 2013 What I noticed most was when I would put the heavy foot down' date=' I lost what cold air was blowing for a couple of minutes, almost like it was catching up with itself ?[/b'] Your A/C system is functioning perfectly normal, given the conditions you've described. The A/C is designed to shut down (as Crash712us stated) under heavy load, or under hard acceleration. All Ford's do this to my knowledge. Once the heavy acceleration is no longer present, the system then comes back on. Sent from my DROID3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
