jlinden7 Posted July 11, 2013 Report Share Posted July 11, 2013 I am having trouble with my 2010 SHO's dual climate zone control. The passenger side will only blow out hot air. I have replaced the Blend Door Actuator and the issue still exists. What troubleshooting steps should I take next to find a resolution? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
SoCalSHO Posted July 11, 2013 Report Share Posted July 11, 2013 I take it you have no warranty left? I had the same problem for a while, took off and reinstalled the blend door actuator, that seems to have fixed it for me. do you even hear any noises when you switch the temp between the sides or change it to defrost? Quote Link to comment Share on other sites More sharing options...
jlinden7 Posted July 11, 2013 Author Report Share Posted July 11, 2013 No warranty, drive way too much - 75k miles. I have not heard the clicking noise since I changed the BDA this morning but it is not cooling at all. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted July 11, 2013 Report Share Posted July 11, 2013 Are you sure you replaced the correct door actuator, I believe there is at least 2 of them in our cars, and I think that someone posted there is 4 of them. Quote Link to comment Share on other sites More sharing options...
jlinden7 Posted July 11, 2013 Author Report Share Posted July 11, 2013 I replaced the one immediately behind the glove box, which I had read is the one that controlled the temperature. Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted July 11, 2013 Report Share Posted July 11, 2013 What mj said, replace the black actuator located to the left of the easy to get to white one behind the glove box, I did this myself recently with the same problem and it solved it. Its a pita just a heads up... Quote Link to comment Share on other sites More sharing options...
jlinden7 Posted July 12, 2013 Author Report Share Posted July 12, 2013 Thanks! Do you have the part number for that one? I appreciate the help! Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted July 12, 2013 Report Share Posted July 12, 2013 Not sure but I recommend taking off the old one and bringing it physically to the parts counter to avoid the parts counter doofus worker lol... Quote Link to comment Share on other sites More sharing options...
jlinden7 Posted July 12, 2013 Author Report Share Posted July 12, 2013 Don't have a Haynes or Chilton. I'm having a hard time seeing the other BDA. Attached is a picture and I assume the yellow arrow I drew is it (red arrow is the white BDA) but wanted to check before I took the other stuff apart that is required to get to it. Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted July 13, 2013 Report Share Posted July 13, 2013 yep thats the one Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted July 13, 2013 Report Share Posted July 13, 2013 http://www.ecoboostownerforums.com/search?q=actuator&searchJSON=%7B%22keywords%22%3A%22actuator%22%7D Quote Link to comment Share on other sites More sharing options...
jlinden7 Posted July 15, 2013 Author Report Share Posted July 15, 2013 You weren't kidding it is difficult to remove. I removed the screws without issues but after a hour last night I couldn't get the stupid BDA out because of the wiring harness in front of it. Will try again tonight. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted July 15, 2013 Report Share Posted July 15, 2013 Anytime! No worries, if its any relief I brought my failed one to Tasca's parts counter after spending quite a bit of time removing it. I told them dont ask me how I got it out, but any tips on getting this back in without destroying it? It was a funny moment. Quote Link to comment Share on other sites More sharing options...
