Wardawg Posted July 12, 2013 Report Share Posted July 12, 2013 Does anyone have any info of how to get access to the shifter handle to tighten it down? Mine has developed a bit of a wobble to it and I'll like to tighten it back up. Took a look at it and couldn't visibly see a way to get at it, and some tugging on the surrounding bezels didn't show any that looked like they would easily pop out. Any info/knowledge/schematics I could get would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted July 12, 2013 Report Share Posted July 12, 2013 Someone had posted a diagram and info on how to tighten it, but I couldn't find it with the search function. Maybe they' or one of the members will respond with the link. Quote Link to comment Share on other sites More sharing options...
geswek Posted July 13, 2013 Report Share Posted July 13, 2013 It was DJE; he's not on here much anymore. Quote Link to comment Share on other sites More sharing options...
Jcl78 Posted July 31, 2013 Report Share Posted July 31, 2013 I had to do this myself when I bought it, it is quite easy, just a little unnerving. What you need is a flathead screwdriver, and gently work your way around the chrome piece right below the shifter handle. There are 2 tabs that snap into the bottom of the handle you need to loosen. Take your time in doing it, you will feel when it disconnects. Once you pull the shift boot down, there are 2 torx screws on the left and right side of the shaft. Tighten those gently, test and you should be good to go. mjhpadi 1 Quote Link to comment Share on other sites More sharing options...
