tdwade Posted May 24, 2014 Report Share Posted May 24, 2014 Anybody else had issues such as car just stopped catching gear to move? Driving along fine then no "GO" when gas pedal is pressed...first time: Second time it started jerking but kept going? Both times the warranty covered it,but both cases were different fixes...CA shop said trans was malfunctioning? KY shop said transmission needed to be reprogrammed? Its all good since the warranty covers all this, but why is this happening when the car has less than 20k on it and not even 1.5 yrs off the lot? Quote Link to comment Share on other sites More sharing options...
Guest Guest Posted May 24, 2014 Report Share Posted May 24, 2014 There have been a couple of guys with similar issues. There may be a TSB on this. Not sure. It could be you need a TCM re flash. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted May 24, 2014 Report Share Posted May 24, 2014 There is at least one TSB for the transmission, sorry I don't have the number available. But it sounds like the kind of problem others have had...I would get it to the dealer...it may take them some time to find the problem. Quote Link to comment Share on other sites More sharing options...
