Blaine109 Posted September 6, 2012 Author Report Share Posted September 6, 2012 Ok, now that I'm back from vacation I want to jump back on this issue. Has anyone had a chance to see if they have any play at all in their driveshaft while in park? I can rotate mine back and forth a little bit with no effort. Haven't really gotten in a position to see if I can completely rotate it with some force. TSB 10-22-04 doesn't really specify if it should be moving at all or if you need to be able to rotate it completely around --> http://way2evil.com/tsb/tsb10-22-04.pdf Thanks, Blaine Link to comment Share on other sites More sharing options...
Crash712us Posted September 6, 2012 Report Share Posted September 6, 2012 Blaine when I did what Red did my car did same thing. I have to rate my tires I will check the drive shaft. Link to comment Share on other sites More sharing options...
Blaine109 Posted September 17, 2012 Author Report Share Posted September 17, 2012 Blaine when I did what Red did my car did same thing. I have to rate my tires I will check the drive shaft. Did you ever get a chance to check on that drive shaft? Link to comment Share on other sites More sharing options...
