74d34h Posted October 13, 2012 Report Share Posted October 13, 2012 I am about to buy a kit and wanted to get some feedback. My main concern is hitting the front end. Is the H&R kit a lower spring kit then the Eibach? I see a mix of installs on everyone's cars here. Some of my roads have dips that stock I have to creep into a turn or pull out onto a road slowly. I had a previously lowered car a while back and just had to be careful not to scrape but it was doable. Quote Link to comment Share on other sites More sharing options...
darreli Posted October 13, 2012 Report Share Posted October 13, 2012 I can only speak for the H&Rs...the drop isn't so much that you scrape on everything. And living in Michigan you'd be hard pressed to have any crappier roads than we have here. My Lighting was lowered 4/6 and I had to worry about scraping on EVERYTHING. Haven't really had that worry with the SHO Quote Link to comment Share on other sites More sharing options...
Paulford8 Posted October 13, 2012 Report Share Posted October 13, 2012 My Eibachs dropped her about 1 inch, from what I understand H&R is more like 2 inches. Not sure about H&R stiffness... The Eibachs have 2 coils of soft so you have some cushion before you hit stiff. Launching at the track I can feel the bit of give, this has led me to consider drag bags in the rear. Quote Link to comment Share on other sites More sharing options...
Rumblebat Posted October 14, 2012 Report Share Posted October 14, 2012 Keep the thread going! I'm wanting to do the same thing and need all the input I can get!!! Quote Link to comment Share on other sites More sharing options...
casperl878 Posted October 14, 2012 Report Share Posted October 14, 2012 me to, please all the input is good and more is better, thanks Quote Link to comment Share on other sites More sharing options...
74d34h Posted October 14, 2012 Author Report Share Posted October 14, 2012 When I dropped my Eclipse GTS back in 2004 I used the Eibach pro kit. I noticed I would get that bouncy feel with the springs sometimes and I wanted to stiffen up the suspension after. Does this kit feel the same on the SHO? Also the custom cam bolts are those needed for install or only when getting the alignment done? Quote Link to comment Share on other sites More sharing options...
FLIP-4-SHO Posted October 14, 2012 Report Share Posted October 14, 2012 I have had both. Started with the H&R's and they worked just fine. I liked the look and feel when driving. I did experience a rub or bottoming out when I failed to reduce speed before a major bump (my fault) that I did not see. It really wasn't a problem thou, far few to really be concerned. I installed some spacers that I fitted to my car. THAT was cool to see on it. Matched it just right. (Pic in my album back shot.) But with the spacers naturally I hit all the time on large bumps when passengers were in back. Since I have my family with me at times it was a no go. I decided to buy the Eibach's. They are installed now. Wow I think these are better on ride. Almost as good as the stock but lower. A bit stiffer than stock but not as stiff as H&R's. I think they are just right now. I started to measure for the spacers and with these springs the wheel is out closer to flush than the H&R's so I would need a true space not adapter that I was using before on all corners. This will require longer studs that I just have not got around to. Way too busy lately for play. Besides I may not do anything at all as far as spacers. Not just yet. I think the next thing maybe the brakes. When I have more time of course. Then either the spacers or New Wheels..... Shhhhh wifey doesn't know yet. :ringing hands: all in good time my friend... all in good time. BWAHAHAHAHAHAHAH! Oh and I may wanna sell the H&R's...... Quote Link to comment Share on other sites More sharing options...
Paulford8 Posted November 2, 2012 Report Share Posted November 2, 2012 Just to clarify the Eibach pro-kit springs are suppose to be a best of all worlds. They are designed to have two "soft" coils with the rest firm. When I launch it gives a little and then it is solid. I like the springs and the feel. That said at the track I want 100% solid, which is why I am looking at dragbags now. Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted November 8, 2012 Report Share Posted November 8, 2012 I am also contemplating which springs to get, but i don't know if i want as much drop as the H&Rs. If there are other members out there besides FLIP-4-SHO (great write-up by the way) that have had both setups, please chime in and give your opinions. pictures would be nice too. Quote Link to comment Share on other sites More sharing options...
74d34h Posted November 8, 2012 Author Report Share Posted November 8, 2012 I am pulling the trigger on Eibachs. Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted November 8, 2012 Report Share Posted November 8, 2012 I am pulling the trigger on Eibachs. Awesome! Please report back your experiences, and be sure to take some pre, during, and post install pics for your fellow members who also are rock'n the Eibach's. I can't think of off hand, there being a whole heckuva lot of images from Eibach owner's. So help out in that area if possible. Look'n forward to hearing about 'em :thumb: Quote Link to comment Share on other sites More sharing options...
SHOdded Posted November 8, 2012 Report Share Posted November 8, 2012 And note the pre-/post-install 60' times, if you race your car at all. Some divided opinion regarding that. Thanks. Quote Link to comment Share on other sites More sharing options...
bigPelo Posted November 8, 2012 Report Share Posted November 8, 2012 I am pulling the trigger on Eibachs. You own a 2013 with performance package right? Quote Link to comment Share on other sites More sharing options...
74d34h Posted November 8, 2012 Author Report Share Posted November 8, 2012 You own a 2013 with performance package right? 2013 Non-pp Quote Link to comment Share on other sites More sharing options...
74d34h Posted November 8, 2012 Author Report Share Posted November 8, 2012 Awesome! Please report back your experiences, and be sure to take some pre, during, and post install pics for your fellow members who also are rock'n the Eibach's. I can't think of off hand, there being a whole heckuva lot of images from Eibach owner's. So help out in that area if possible. Look'n forward to hearing about 'em :thumb: 3wks backorder at LMS on the Eibachs. I will have someone install for me my mechanic abilities are limited to bikes! Quote Link to comment Share on other sites More sharing options...
Paulford8 Posted November 9, 2012 Report Share Posted November 9, 2012 3wks backorder at LMS on the Eibachs. I will have someone install for me my mechanic abilities are limited to bikes! I have a Trek 1.1 and would much rather tackle springs any day of the week then try to dial in the Trek. I can bolt crap together but dialing in a bike takes finesse. Quote Link to comment Share on other sites More sharing options...
74d34h Posted November 9, 2012 Author Report Share Posted November 9, 2012 I have a Trek 1.1 and would much rather tackle springs any day of the week then try to dial in the Trek. I can bolt crap together but dialing in a bike takes finesse. I miss my 11 gsxr750. I had the auto tuner with PCV and an R77 full exhaust. I loved dialing her in. Once I'm healed up and back to it it will be the new ZX10R ABS. I can work on bikes all day, not so with a car! [ATTACH=CONFIG]1245[/ATTACH] Quote Link to comment Share on other sites More sharing options...
Paulford8 Posted November 10, 2012 Report Share Posted November 10, 2012 I thought we were talking bicycles, I am just scared of them. I am terrified of motorcycles! I havent had anything as fast as you, probably fastest one I had was a Yamaha Maxim X, never had a sport bike either. Although that Maxim X was a sport bike motor. I cant handle the whole engine and trans in the same case. I had an old Honda CB750, went to do something to the engine and I had transmission parts falling all over the place. I have steered clear of any serious wrenching on bikes every since... Quote Link to comment Share on other sites More sharing options...
Lesterg69 Posted November 10, 2012 Report Share Posted November 10, 2012 I have H&R on my vehicle do have to be careful on inclines but I like the lowered look I think it made the car look tons better. The ride is not terrible but you can feel a difference from stock. I just posted pics of my car this evening if you want to see how low it will go. Quote Link to comment Share on other sites More sharing options...
