Escort 9500ix and live smart hardwire.
Here's what the service manual says for the 2011 model year:
Unsnap the connector access cover from the LH side of the HCM-2 .
Disconnect the electrical connector from the headliner harness.
NOTICE: Do not use a metal tool or screwdriver, or pry on the cover or bracket. Damage to the bracket or windshield can occur.
NOTE: The snap locations are marked on the HCM-2 housing with 2 very small cutouts on the RH side.
NOTE: The HCM-2 is removed by separating the right side of the assembly from the windshield and sliding to the right. There is also hook-and-loop tape between the inside of the cover and the rain sensor.
While gently pulling downward on the right side of the cover, insert a thin plastic flat-bladed tool at each cutout notch and release the retaining clips.
Separate the HCM-2 from the windshield and disconnect the electrical connector from the rain sensor.
-Rod
If you tap into one of the empty "accessory" fuse slots under the drivers side dash, you will get instant on/off with ignition. I was having a heck of a time with it back when i hard-wired my 955, thinking one of the navigation or audio fuses would work for this but they stayed on even with the ignition off. I think i ended up trying almost every fuse until i decided to try one of the empty "accessory" slots. /facepalm
