since 1964 Posted December 6, 2012 Report Share Posted December 6, 2012 Can anyone advise me on how to stop this? Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted December 6, 2012 Report Share Posted December 6, 2012 There is a TSB about the rattle in this area, it has too do with the rear window shade, not sure the exact fix, also, if you have the stereo in the surround sound mode, try it on the stereo mode, since the surround sound mode is really terrible, the radio will sound better with it in some other mode. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted December 6, 2012 Report Share Posted December 6, 2012 Also have someone with good hearing ride in the back seat to confirm the source of the rattle. I had a rattle that I swore was in the rear. I tore the sunshade out, padded any areas where it could rub, installed Dynamat on the package tray, put it all back together, rattle was still there. So then I swore it was in the passenger door. I took the door apart, inspected everything, put some Dynamat on it, got it all back together, still the same rattle. With passengers in the car I would ask others if they could hear the noise. Almost no one would hear the rattle, and if they did, they would think it was coming from different locations than I would. I ended up finding the rattle above the passenger headliner forward of the sunroof. There's a little cable bundle up there that is not staked down and rattles against the headliner. -Rod Quote Link to comment Share on other sites More sharing options...
racerx78 Posted December 6, 2012 Report Share Posted December 6, 2012 I've had this issue. Initially thought it was a blown speaker, so we replaced it and i still had the rattle. Come to find out that it was the rear headliner around the 3rd brake light. After they had the car for a few days and testing this on a new car they said it is just something that every car does. I can confirm that to be true as i first had this issue with my '10 and with my '13. Trying having someone put their hand up near the headliner/brake light area and see if it stops it. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted December 6, 2012 Report Share Posted December 6, 2012 Good info, great to know so if you have the noise, we now know where to look first. Thanks! Quote Link to comment Share on other sites More sharing options...
since 1964 Posted December 8, 2012 Author Report Share Posted December 8, 2012 When I hold the area in the middle by the seat it stops . Any advice? Quote Link to comment Share on other sites More sharing options...
Guest K4u2luz2 Posted January 19, 2013 Report Share Posted January 19, 2013 I have a '10 and it seems to be really bad now that I have added (2) JL Audio subs. Like odors have mentioned above the rattle seems to be coming from overhead. And if it wasn't so darn cold outside I would be tearing into the headliner issue. So I will report back in the spring or when it gets warmer. Quote Link to comment Share on other sites More sharing options...
SoCalSHO Posted January 25, 2013 Report Share Posted January 25, 2013 When I get rattles in the rear of my 2010, I raise the sunscreen and they go away. Quote Link to comment Share on other sites More sharing options...
yowen2000 Posted January 28, 2013 Report Share Posted January 28, 2013 Just got my SHO last week and it has the rattles as well, highly annoying! Because the sounds systems seems to be halfway decent otherwise. Certainly better than the '06 500 I traded it for. I bought a 2 yr/36 k warranty with the car from Ford, would getting this rattle fixed be covered? Quote Link to comment Share on other sites More sharing options...
