larrylu Posted March 6, 2013 Report Share Posted March 6, 2013 Probably everyone here but me knows this but.....just in case someone else does not, this is what I just learned. The spare (I don't have a PP) has a sensor and will cause a fault reading if it gets below 35 lbs. I guess I forgot to check the spare when doing the others, and when I got the fault I stopped ASAP and checked all four corners and they were right where I set them. A few days later at exactly the same stretch of road, I got another fault. A call to my service manager and I got the reminder to check the spare. Sure enough it was down from 60 lbs. to 35 lbs. OOPS! mjhpadi and gregoire 2 Quote Link to comment Share on other sites More sharing options...
brucelinc Posted March 6, 2013 Report Share Posted March 6, 2013 Wow! I did not know that! I guess I assumed that there was a sensor in the spare but I thought it would need to be mounted on the hub before it would send any info. Once again, I have learned something. Thanks Larry! Quote Link to comment Share on other sites More sharing options...
halo3kbb Posted March 8, 2013 Report Share Posted March 8, 2013 Thanks Larry! Didn't know either, as much sense as it really does make... Quote Link to comment Share on other sites More sharing options...
83racecrew Posted March 8, 2013 Report Share Posted March 8, 2013 When I read this, I thought your Throttle Position Sensor failed. TPMS sensor monitors the tire pressure PS: This is just my OCD brain making a post and it completely irrelevant. Have a great Friday! PPS: Good tip though, thanks. Quote Link to comment Share on other sites More sharing options...
baggedsvt Posted March 9, 2013 Report Share Posted March 9, 2013 When I read this, I thought your Throttle Position Sensor failed. TPMS sensor monitors the tire pressure PS: This is just my OCD brain making a post and it completely irrelevant. Have a great Friday! PPS: Good tip though, thanks. Thats what I was thinking from the title of the thread lol. Damn ford even monitors the spare tire pressure lol. Quote Link to comment Share on other sites More sharing options...
