Night Hawk Posted April 9, 2013 Report Share Posted April 9, 2013 This past week had a full set of perf spec shocks struts and Eibach spring kit ready for install along with a 170 thermo, new EBC rotors, and fluid for the front PTU and rear diff (my car has 77k) the rear end went well with the rear springs and shocks going in good to go along with the rear diff fluid being swapped out without it appearing too bad. Now the fun part was after pulling off the front strut. I had checked the boxes which were clearly marked with separate part numbers that ended up being both for the same passenger's side. I figured no prob Rock auto is good to go, I'm sure they will realize their mistake in sending the wrong part that I requested and paid for. When I contact them they told me there was nothing they could do , not even split the expedited replacement shipping so I wouldn't be without a car. They told me they could not ship until the return was scanned so I did. I was then told they would not have a replacement for 7 to 10 days. I was ripped!! i ended up with an ebay back up plan and had one shipped out, glad i did as I was emailed today that they in fact were not shipping a replacement and would simply refund my credit. I had good luck with them for years too bad they decided to suck. Now to the PTU Fluid, If you have not replaced your fluid with 35k or better I highly recommend you do as I took the fill plug out (front p/s wheel well access, I noticed what was once 18oz of fluid was now a grey paste consistent with cake frosting. Even after using a vacuum tool I was only able to remove a fraction of it. I ended up topping it off with 10oz of clean stuff, and found on another website a pic of a PTU taken apart after a failure again looks like the fluid turns to paste and adheres to the internals and walls. Pics to follow!! Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted April 10, 2013 Author Report Share Posted April 10, 2013 [ATTACH=CONFIG]2285[/ATTACH][ATTACH=CONFIG]2285[/ATTACH][ATTACH=CONFIG]2286[/ATTACH] the magnetic plug before and after and the third is a pic of the sludge making its way through the vacuum tube. Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted April 10, 2013 Author Report Share Posted April 10, 2013 [ATTACH=CONFIG]2287[/ATTACH] THIS is the after lol Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted April 10, 2013 Author Report Share Posted April 10, 2013 [ATTACH=CONFIG]2288[/ATTACH] ahhh the icing on the cake Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted April 10, 2013 Report Share Posted April 10, 2013 Wow, I am glad I decided to do this next time I have the car up for service. Amazing how bad it looks. Quote Link to comment Share on other sites More sharing options...
12sho Posted April 10, 2013 Report Share Posted April 10, 2013 This definately seems to be the weak link in our drive train. I had an AWD Fusion before the SHO and the PTU went out at 35k. When you fill it do you add until it comes out the fill hole or is it 1 inch below? Quote Link to comment Share on other sites More sharing options...
glock-coma Posted April 10, 2013 Report Share Posted April 10, 2013 Sorry about your rock auto experience. I bought several items from them years ago, but never had to return anything. Thanks for the pics of the PTU, I know what I'll be doing this weekend..... Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted April 10, 2013 Author Report Share Posted April 10, 2013 This definately seems to be the weak link in our drive train. I had an AWD Fusion before the SHO and the PTU went out at 35k. When you fill it do you add until it comes out the fill hole or is it 1 inch below? I filled it to the bottom of the fill hole plugged it when it stopped weeping out. I'll be doing it again in a month in hopes the new stuff will loosen up the thick crud. Quote Link to comment Share on other sites More sharing options...
racerx78 Posted April 10, 2013 Report Share Posted April 10, 2013 that is why I'm changing my Drivetrain fluide every year. Quote Link to comment Share on other sites More sharing options...
TractorAK Posted April 10, 2013 Report Share Posted April 10, 2013 I'm only @ 12347.1 but sounds like i will change. I am fond of changing fluid it is cheap insurance. Especially if you play hard. Quote Link to comment Share on other sites More sharing options...
RedCandySHO Posted April 10, 2013 Report Share Posted April 10, 2013 How hard is it to get to the drain / fill plugs? Quote Link to comment Share on other sites More sharing options...
Crash712us Posted April 10, 2013 Report Share Posted April 10, 2013 No drain plugs, but getting to them isn't to hard at all. Quote Link to comment Share on other sites More sharing options...
RedCandySHO Posted April 11, 2013 Report Share Posted April 11, 2013 So how do you get out the old fluid? Vacuum via the fill plug? Quote Link to comment Share on other sites More sharing options...
SHOdded Posted April 11, 2013 Report Share Posted April 11, 2013 A most recent discussion on the PTU fluid change: http://www.ecoboostownerforums.com/showthread.php?2027-Needs-some-help-with-PTU-fluid-Change Looks like jack stands/lift, a mityvac or similar hand pump, new fluid, and drain pan required at minimum. Quote Link to comment Share on other sites More sharing options...
Blaine109 Posted April 12, 2013 Report Share Posted April 12, 2013 We need a good "How To..." write-up with pics. Quote Link to comment Share on other sites More sharing options...
shomeda- Posted April 12, 2013 Report Share Posted April 12, 2013 I second that!!! I am planning on installing my downpipes this weekend and would like to knock this out as well!!!!! and possibly the rear diff as well!!!! Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted April 13, 2013 Author Report Share Posted April 13, 2013 [ATTACH=CONFIG]2306[/ATTACH][ATTACH=CONFIG]2307[/ATTACH][ATTACH=CONFIG]2308[/ATTACH][ATTACH=CONFIG]2309[/ATTACH][ATTACH=CONFIG]2310[/ATTACH][ATTACH=CONFIG]2309[/ATTACH] some pics from the shocks/struts/ I opted for the Performance Package replacement shocks and struts, eibach spring install also shown is the "hat" that sits on the spring, I found upon removal that they actually has bearings in it so I swapped them out too. The final product stance with the new set up. Quote Link to comment Share on other sites More sharing options...
pacoflyer Posted April 19, 2013 Report Share Posted April 19, 2013 Which Shocks struts did you use? Are they from ford or did you find a aftermarket vendor? Also what was the bearing part numbers? Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted April 19, 2013 Author Report Share Posted April 19, 2013 I went with the PP spec shocks/struts Rears are ASH453 front D/S AST886 P/S AST887 the hats are AD1076, I highly recommend checking your front wheel bearings/hubs while its pulled apart esp if you have north of 35k. Despite my many arguments with parts counter guys, as my sho is a non PP, these do fit. bpd1151 1 Quote Link to comment Share on other sites More sharing options...
pacoflyer Posted April 20, 2013 Report Share Posted April 20, 2013 Is the rears AST443? Because ASH443 didn't come up. Would I need two hats? Quote Link to comment Share on other sites More sharing options...
Night Hawk Posted April 20, 2013 Author Report Share Posted April 20, 2013 Is the rears AST443? Because ASH443 didn't come up. Would I need two hats? ASH 453 my typo, yep you'll need two Quote Link to comment Share on other sites More sharing options...
