Rockgt302 Posted May 22, 2013 Report Share Posted May 22, 2013 When I start my car, my sub flutters ( for the lack of a better word). It's like some signal is being sent through. Any ideas? Quote Link to comment Share on other sites More sharing options...
Kolk1 Posted May 22, 2013 Report Share Posted May 22, 2013 Factory sub, or aftermarket setup? Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted May 23, 2013 Report Share Posted May 23, 2013 Do you have the sound system set in Surround Mode or Stereo? Quote Link to comment Share on other sites More sharing options...
Rockgt302 Posted May 24, 2013 Author Report Share Posted May 24, 2013 Aftermarket sub, set to stereo Quote Link to comment Share on other sites More sharing options...
SHOdded Posted May 24, 2013 Report Share Posted May 24, 2013 Sounds like the amp's output and the sub's frequency range may be mismatched, or you need a better crossover? Quote Link to comment Share on other sites More sharing options...
Kolk1 Posted May 24, 2013 Report Share Posted May 24, 2013 Sub pop on turn on, try a couple different options. Bad Ground on the amp is normally the cause of this. Make sure you have the ground bolted to a bare/unpainted piece of metal. If you disconnect the RCA's to amp, does it still happen? Are you using a LOC? Or a high level input on the amp? Also, if you have some resistors laying around, trying adding some resistance to the Remote turn on wire, to slightly lower the voltage during turn on. Quote Link to comment Share on other sites More sharing options...
Rockgt302 Posted May 24, 2013 Author Report Share Posted May 24, 2013 I'm using a ReQ as a line level converter. Quote Link to comment Share on other sites More sharing options...
Kolk1 Posted May 25, 2013 Report Share Posted May 25, 2013 ok, well try turning it on with the RCAs unplugged, to make sure its not from the ReQ as well. Quote Link to comment Share on other sites More sharing options...
