ShoBoat Posted June 16, 2013 Report Share Posted June 16, 2013 This mod has taken me quite some time to complete, I sourced the LED bulbs locally and the color was always off. They all had quite a bit of blue in the bulbs. Some almost to the point of being purple?? So I mucked around with this for a few weeks. I even changed the HID's to 6000K just to get it to match. No dice as the LED lower markers are about a 5000K color. Just my 2 cents if you want to match your OEM 4300K HID and the OEM lower LED markers get the ones I have listed. I literately went through 3 sets of switch back bulbs before these. The running lights are really bright. almost like adding a set of fog lights. Also on approach when you unlock the car they light up the areas in front of the car really well. The Switchbacks are VLEDS 5000K 3157 Type 2 dual color bulbs The Corners are 5000K 194 Bulbs You will also need a pair of load resistors to eliminate hyper-flash. I went with 8 ohm 50W but 6 ohm 50W is more readily available and will work too. The install is fairly simple (sort of lol) The switchbacks are easier to install and you can access from inside the engine compartment. Driver side is piece of cake. Remove the socket and plug in the bulb. You need to use wire taps to link the load resistor to the 2 outside wires on the harness. I would double check with a volt meeter which is ground and the turn signal. Mount the load resistor to metal. I mounted mine to the inner fender wells with Loctite 3873 is a fast curing, high-conductivity, adhesive. And that seemed to work well. On the passenger side it was a little harder to get the wire taps on. I removed the tube going to the throttle body to give me more space to work. The side markers are a PITA!. You will have to remove the wheel and the plastic outer fender well. Once you have those off now begins the cursing. If your hands are small enough you can reach up and grab the socket and twist it out. My hands are not that small (what was ford thinking?) Instead I used a long pair of needle nose pliers to just twist the socket enough to break to free. Then I was able to get my fingers on it and remove it. Installation is also a PITA, you have to insert the bulb and socket had just get it to grab with your hand. Once you do then and only then use the pliers carefully. You could break the housing if not careful. Done, just put if back together and enjoy!! I'll add the links to the products below. Below is only parking lights, no headlights. http://www.vleds.com/5k-type-2-dual-...57-1-pair.html http://www.vleds.com/bulb/194-168-15...25-1-pair.html http://www.vleds.com/resistors/led-l...ix-1-pair.html http://www.henkel.com/fullproductlis...UID=00000002KJ SHOdded 1 Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted June 16, 2013 Author Report Share Posted June 16, 2013 Sorry, I couldn't get the links and pics to show. Ill try again later. Quote Link to comment Share on other sites More sharing options...
SHOdded Posted June 16, 2013 Report Share Posted June 16, 2013 Glad you got the lighting color matched! I have found this to be problematic batch-to-batch, at least the "cheaper" sites. Re: the links/pics, you have to put them in all at one time I believe. Then preview your post before saving. Normally that should work. I have resorted to cutting and pasting the entire post into a text editor, adding the links, then copying back into the post to get these to work. Quote Link to comment Share on other sites More sharing options...
anthonylee337 Posted June 16, 2013 Report Share Posted June 16, 2013 Would love to see pics Quote Link to comment Share on other sites More sharing options...
geswek Posted June 17, 2013 Report Share Posted June 17, 2013 I'm interested in knowing how you did switch backs too! Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted June 17, 2013 Author Report Share Posted June 17, 2013 Ill post a full write up tomorrow with pics. Having some issues connecting from my home. Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted June 17, 2013 Author Report Share Posted June 17, 2013 Pics and links are up Quote Link to comment Share on other sites More sharing options...
icecam Posted June 17, 2013 Report Share Posted June 17, 2013 Nice Could you do a little test for me? http://www.ecoboostownerforums.com/forum/ecoboost-taurus-sho-mks-forum/ecoboost-sho-mks-appearance-detailing/51842-question-for-anybody-with-switchbacks put a regular bulb back in and see if it still works with the load resistor? Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted June 18, 2013 Author Report Share Posted June 18, 2013 Nice Could you do a little test for me? http://www.ecoboostownerforums.com/forum/ecoboost-taurus-sho-mks-forum/ecoboost-sho-mks-appearance-detailing/51842-question-for-anybody-with-switchbacks put a regular bulb back in and see if it still works with the load resistor? Question answered, I think at least Quote Link to comment Share on other sites More sharing options...
dalum Posted June 18, 2013 Report Share Posted June 18, 2013 I might have to go this route since I know it works on a '13. I got their http://www.vleds.com/v3-triton.html. Version 1 would blow parking light fuse. Version 2 killed my smart junction box (bcm). So I'm a little nervous now. Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted June 18, 2013 Author Report Share Posted June 18, 2013 Crap, I have the v2 in mine with no issues. Quote Link to comment Share on other sites More sharing options...
dalum Posted June 19, 2013 Report Share Posted June 19, 2013 No, I have the v3 triton version 2. Not the ones you have in your links. Quote Link to comment Share on other sites More sharing options...
icecam Posted June 19, 2013 Report Share Posted June 19, 2013 No' date=' I have the v3 triton version 2. .[/quote'] I want those.. but at the moment they are a bit pricey. I'll wait until the price comes down and then get some I hope you get them working as they are suppose to Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted June 19, 2013 Author Report Share Posted June 19, 2013 I might have to go this route since I know it works on a '13. I got their http://www.vleds.com/v3-triton.html. Version 1 would blow parking light fuse. Version 2 killed my smart junction box (bcm). So I'm a little nervous now. Just out of curiosity have you tried to wire them without the built in load resistor? Quote Link to comment Share on other sites More sharing options...
