bpd1151 Posted February 14, 2012 Report Share Posted February 14, 2012 Wanted to express my complete gratitude to fellow forums member dbulldog for compiling this following list of TSB's that apply to the 2010-2012 model year's of SHO's. dbulldog pm'd me this list the other day after advising that he finally "found" this site. I hope each of you take a moment to visit dbulldog's EB profile page and both welcome him here, and thank him for this gi-normous contribution thumb: To that end, on with the info....... 2010 • 11-12-10 - 6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011 • 11-11-20 - DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES • 11-11-16 - SIRIUS RADIO WITH NAVIGATION - VARIOUS FUNCTIONALITY CONCERNS - BUILT ON OR BEFORE 3/8/2010 • 11-11-09 - INTERMITTENT STEERING DRIFT/PULL - BUILT ON OR BEFORE 6/11/2010 • 11-10-07 - INTERMITTENT AIR BAG WARNING INDICATOR - DTCS B0028, B1213 WHEN PASSENGER CLIMATE CONTROL SEAT COMMANDED ON • 11-08-19 - 3.5L GTDI ENGINE RUNS ROUGH, HESITATES, SHUDDERING WITH MISFIRE DTCS P0300, P0301, P0302, P0303, P0304, P0305, P0306 OR P0316 • 11-08-03 - BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE BLOCKAGE AND/OR DIAGNOSTIC TROUBLE CODE(DTC) - U3000 - BUILT ON OR BEFORE 3/29/2011 • 11-05-15 - FRONT BRAKES - INTERMITTENT GRUNT OR GRINDING NOISE • 11-04-20 - 6F50/6F55 TRANSMISSION AWD - FLUID LEAK - BETWEEN PTU ASSEMBLY AND TRANSMISSION CASE • 10-22-04 - AWD VEHICLES - SHUDDER/CHATTER/VIBRATION ON TURNS OR THUMP/CLUNK NOISE ON LIGHT ACCELERATION - BUILT 10/1/2009 TO 12/31/2009 • 10-21-06 - DTC P2111 OR P2112, OR LOWER THAN DESIRED ENGINE IDLE SPEED, ENGINE IDLE SPEED FLUCTUATES WITH OR WITHOUT DTCS • 10-21-02 - 6F50/6F55 TRANSMISSION - SLIP/NEUTRAL OUT, 5TH GEAR START FROM STOP, ELECTRONIC PRNDL ERROR, BACKUP CAMERA IN D - BUILT 3/13/2009-6/30/2010 • 10-20-08 - TIP-IN DELAYED SHIFT AT SPEEDS BETWEEN 15-20 MPH (24-32 KM/H) • 10-20-06 - BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE DTC B11D6:15 WITH INTERMITTENT FAULTS - BUILT ON OR BEFORE 5/21/2010. • 10-18-07 - SPEEDOMETER INDICATOR NEEDLE STICKING OR INACCURATE - BUILT ON OR BEFORE 3/25/2010 • 10-15-02 - CENTER HIGH MOUNT STOPLAMP REPAIR/REPLACEMENT PROCEDURE • 10-14-02 - PTU FLUID LEAK - VENT AREA • 10-13-04 - SYNC NON-NAVIGATION - NO TURN-BY-TURN DIRECTIONS AND/OR UNABLE TO PIN POINT VEHICLE LOCATION - BUILT ON OR BEFORE 6/14/2010 • 10-13-03 - FM RADIO RECEPTION/SOUND QUALITY CHANGES WHILE DRIVING OR SATELLITE RADIO SIGNAL BLEED THROUGH WHEN USING AUDIO SYSTEM IN AUX MODE • 10-09-09 - 6F50/6F55 TRANSMISSION - DTC P0751 - HARSH OR NO FORWARD ENGAGEMENTS - PERCEIVED SLIP ON ACCELERATION - SLIP/DELAYED AND/OR HARSH DOWNSHIFTS • 10-08-03 - SYNC - CALL SOUND QUALITY/BACKGROUND NOISE ISSUES AND/OR VOICE RECOGNITION DIFFICULTIES WHILE DRIVING • 10-08-01 - ADAPTIVE CRUISE CONTROL (ACC) - TURNS OFF • 10-07-02 - REAR BRAKE DRAG OR REAR BRAKE NOISE - BUILT ON OR BEFORE 12/14/2009 • 10-06-04 - 6F55 TRANSMISSION WITH ECO BOOST (GTDI)- BUMP 3-1 COASTING DOWNSHIFT BELOW 10 MPH (16 KM/H) BUILT ON OR BEFORE 3/1/2010 • 10-06-02 - REAR PACKAGE TRAY/SPEAKER RATTLE/BUZZ WITH THE RADIO ON - BUILT ON OR BEFORE 12/9/2009 • 10-06-01 - POWER STEERING FLUID LEAK AT THE RESERVOIR FILL CAP • 10-05-12 - INTELLIGENT ACCESS KEY WITH NO KEY DETECTED OR NO FOB DETECTED - BUILT ON OR BEFORE 3/11/2010 • 10-05-09 - LUGGAGE COMPARTMENT LID SOLENOID STUCK OPEN • 10-04-03 - 6F50/6F55 TRANSMISSION - SHIFT FLARE INITIAL 2-3 SHIFT / SLIGHT DELAY/BUMP 3-1 COASTING DOWNSHIFT BELOW 10 MPH (16 KM/H) BUILT ON OR BEFORE 11/17/2009 • 10-02-08 - SYNC SYSTEM DEFAULTS TO OR STAYS IN PRIVACY MODE, MULTIPLE VEHICLE LINES • 10-02-06 - AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION, NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS • 09-25-07 - SERVICE TIP - POWER TRANSFER UNIT (PTU) - RIGHT HAND INTERMEDIATE SHAFT SEAL LEAKS • 09-24-13 - RAIN SENSOR MOUNTING RING DETACHED FROM WINDSHIELD • 09-23-08 - DTC P0096-INTAKE AIR TEMPERATURE: IAT SENSOR 2 CIRCUIT/RANGE PERFORMANCE - BANK 1 - BUILT ON OR BEFORE 10/14/2009 • 09-23-02 - RADIO - HIGH PITCH WHISTLE OR WHINE NOISE BUILT ON OR BEFORE 9/24/2009 • 09-19-02 - POOR AM / FM RADIO RECEPTION WITH REAR DEFROST ON 2011 • 12-01-16 - SYNC - INTERMITTENT VOICE RECOGNITION - BUILT ON OR BEFORE 6/15/2011 • 11-12-10 - 6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011 • 11-11-20 - DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES • 11-10-29 - FRONT BRAKES - INTERMITTENT SQUEAL • 11-10-07 - INTERMITTENT AIR BAG WARNING INDICATOR - DTCS B0028, B1213 WHEN PASSENGER CLIMATE CONTROL SEAT COMMANDED ON • 11-08-19 - 3.5L GTDI ENGINE RUNS ROUGH, HESITATES, SHUDDERING WITH MISFIRE DTCS P0300, P0301, P0302, P0303, P0304, P0305, P0306 OR P0316 • 11-08-03 - BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE BLOCKAGE AND/OR DIAGNOSTIC TROUBLE CODE(DTC) - U3000 - BUILT ON OR BEFORE 3/29/2011 • 11-07-21 - COOLING FAN NOISE, LACK OF A/C AND/OR OVERHEAT CONDITION • 11-05-15 - FRONT BRAKES - INTERMITTENT GRUNT OR GRINDING NOISE • 10-21-06 - DTC P2111 OR P2112, OR LOWER THAN DESIRED ENGINE IDLE SPEED, ENGINE IDLE SPEED FLUCTUATES WITH OR WITHOUT DTCS • 10-21-02 - 6F50/6F55 TRANSMISSION - SLIP/NEUTRAL OUT, 5TH GEAR START FROM STOP, ELECTRONIC PRNDL ERROR, BACKUP CAMERA IN D - BUILT 3/13/2009-6/30/2010 • 10-15-02 - CENTER HIGH MOUNT STOPLAMP REPAIR/REPLACEMENT PROCEDURE 2012 • 11-11-20 - DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES • 11-10-29 - FRONT BRAKES - INTERMITTENT SQUEAL Showgun 1 Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted February 14, 2012 Report Share Posted February 14, 2012 Wow, this was a lot of work and is very well done. Thanks to dbulldog for all the work. I'm sure all the members will find this helpful! Quote Link to comment Share on other sites More sharing options...
FLIP-4-SHO Posted February 14, 2012 Report Share Posted February 14, 2012 Thank you dBulldog. Quote Link to comment Share on other sites More sharing options...
SHO-MAN Posted February 14, 2012 Report Share Posted February 14, 2012 Good information and very informative. Nice reference when problems arise. Quote Link to comment Share on other sites More sharing options...
SoCalSHO Posted February 21, 2012 Report Share Posted February 21, 2012 Yes, thanks for all the work. Now, where can we get the narrative of the TSB's? I am looking for 11-11-20 and 11-12-10. Thanks Quote Link to comment Share on other sites More sharing options...
markssho Posted February 27, 2012 Report Share Posted February 27, 2012 Thanks for compiling this list! Now if we just had links to the .pdf's for each one.... Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted March 4, 2012 Author Report Share Posted March 4, 2012 Now' date=' where can we get the narrative of the TSB's? I am looking for 11-11-20 and 11-12-10. Thanks[/b'] TSB 11-11-20 DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES Publication Date: November 17, 2011 FORD: 2010-2012 Taurus ISSUE: Some 2010-2012 Taurus vehicles may exhibit road dust accumulation on the rear door scuff plate area. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Paint the replacement body quarter trim panel from the Dust Kit to match the vehicle exterior color. Install the Dust Kit parts. Refer to instruction sheet included in the kit. PART NUMBER PART NAME AG1Z-5420530-D Dust Kit WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT: Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. OPERATION DESCRIPTION TIME 111120A 2010-2012 Taurus: Install The Revised Weatherstrip Kit Following The Kit Instructions. Can Be Claimed With Operations B And C As Necessary 2.3 Hrs 111120B 2010-2012 Taurus: Additional Time To Prep and Paint New Molding Assemblies. Can Be Claimed With Operations A And C 1.5 Hrs 111120C 2010-2012 Taurus: Additional Time For Vehicles With Tri-Coat Finish. Can Be Claimed With Operation A And B 0.5 Hr. DEALER CODING BASIC PART NO. CONDITION CODE 5420530 42 __________________________________________________ __________________________________________________ _________________ TSB 11-12-10 6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011 Publication Date: December 19, 2011 FORD: 2010-2011 Taurus 2009 Edge, Flex 2010-2011 Edge, Flex 2011 Explorer LINCOLN: 2010-2011 MKS 2009 MKX 2010-2011 MKT, MKX This article supersedes TSB 11-9-11 to update the Service Procedure. ISSUE: Some 2009 Edge, MKX and Flex vehicles built on or after 5/4/2009, 2010-2011 Edge, Flex, MKS, MKT, MKX, Taurus and 2011 Explorer vehicles built on or before 4/15/2011 may have a sluggish acceleration or hesitation feel during a rolling stop 0-8 Km/h (0-5 MPH) followed by a harsh bump or feel like a slip on take-off from a stop followed by a harsh bump. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE This valve body modification is only available for transmissions originally built with MERCON® LV listed on the dipstick. There is a new calibration and transmission valve body change to correct this condition. The valve body change was to delete one hole in the valve body separator plate and remove one check ball from the valve body in the same area where the hole in the separator plate was deleted. NOTE: IF THIS PROCEDURE IS NOT FOLLOWED CORRECTLY, ADDITIONAL NEW CUSTOMER SYMPTOMS WILL BE PRESENT, SUCH AS LOSS OF REVERSE OR 2-3 SHIFT FLARE. For all model years except 2009, proceed to Step 2. For 2009 model year vehicles, verify the transmission dipstick has MERCON® LV listed on the dipstick. Yes - The dipstick has MERCON® LV listed on the dipstick; proceed to Step 2. No - The dipstick does not have MERCON® LV listed on the dipstick; this procedure does not apply. Follow normal Workshop Manual diagnostics. Reprogram the PCM to the latest calibration using IDS release 73.04 and higher. This new calibration is not included in the VCM 2011.5 DVD. Calibration files may also be obtained at http://www.motorcraft.com. Remove the transmission valve body. Refer to the Workshop Manual (WSM), Section 307-01. Replace both separator plates listed in the Parts List. The X identifies the hole in the valve body separator plate which will be eliminated. (Figure 1) Figure 1 - Article 11-12-10 Remove one (1) check ball identified as X. (Figure 2) Figure 2 - Article 11-12-10 Proper check ball locations on the remaining six (6) valve body check balls shown with arrows. (Figure 2) Install transmission valve body. Refer to WSM, Section 307-01. PART NUMBER PART NAME BT4Z-7Z490-B Valve Body Separator Plate 7T4Z-7Z490-D Valve Body Separator Plate WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage IMPORTANT: Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. OPERATION DESCRIPTION TIME 111210A 2009-2011 Edge And MKX: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.0 Hrs. 111210A 2010-2011 Taurus And Flex 3.5L DOHC, MKS And MKT 3.7L, 2011 Explorer 3.5L: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.0 Hrs. 111210A 2010-2011 Taurus, MKS, Flex, And MKT 3.5L GTDI: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.1 Hrs. DEALER CODING BASIC PART NO. CONDITION CODE 7A100 42 Quote Link to comment Share on other sites More sharing options...
SoCalSHO Posted March 9, 2012 Report Share Posted March 9, 2012 TYVM Mike. I kinda figured 11-12-10 would read like the others. But There is hope for my door seal. Now I just have to part with my car for a day or two. Is there a site we can subscribe to to get the TSB's? Quote Link to comment Share on other sites More sharing options...
dbulldog Posted March 9, 2012 Report Share Posted March 9, 2012 SoCalSHO TYVM Mike. I kinda figured 11-12-10 would read like the others. But There is hope for my door seal. Now I just have to part with my car for a day or two. Is there a site we can subscribe to to get the TSB's? Since I'm the person that offered all the TSB information, it's probably best that I respond. If there is a site to do this, I am not aware of it at this time. If you 'Google' the TSB (i.e. Ford TSB 11-12-10), there are many responses including the PDF. I wish I could offer the links but this is a secure site. I'm sure you'll understand. I will of course update Mike as new TSB's come and help out the community as much as I can. Have a great day! Brian Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted March 9, 2012 Author Report Share Posted March 9, 2012 Thanks Brian for all the help that you have provided thus far to the EB Community. Although I haven't used any of the following links, maybe these will help some of you out in the event that Brian no longer can provide this info (let's hope that he still can though)..... http://www.automd.com/tsb/ford_m http://www-odi.nhtsa.dot.gov/tsbs/ Hope that's of some help :RpS_thumbup: Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted April 27, 2012 Author Report Share Posted April 27, 2012 **RECENTLY ADDED** .....and applies to 2010 MY's: 12-02-08 - INTERMITTENT STEERING DRIFT/PULL - BUILT ON OR BEFORE 6/11/2010 FORD: LINCOLN: 2010 Taurus, Flex 2010 MKS, MKT This article supersedes TSB 11-11-9 to update the Integrated Diagnostic System (IDS) calibration. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited ISSUE Warranty Coverage Some 2010 Taurus, MKS, Flex and MKT vehicles built on or before 6/11/2010 and equipped with a 3.5L gasoline turbo direct injection (GTDI) engine may exhibit an intermittent steering pull/drift left or right. A customer may describe the condition as one where they believe the vehicle needs a front end alignment. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. ACTION OPERATION DESCRIPTION TIME Reprogram the power steering control module 120208A 2010 Flex, MKT, Taurus, 0.3 Hr. (PSCM) to the latest calibration using IDS release And MKS 3.5L GTDI: 75.04 and higher. This new calibration is not Reprogram The Power included in the VCM 2011.9 DVD. Calibration files Steering Control Module may also be obtained at http://www.motorcraft.com. (Do Not Use With Any While reprogramming the PSCM the IDS may automatically reprogram the anti-lock brake system (ABS) module. As a result, during the PSCM Other Labor Operations) DEALER CODING CONDITION programming procedure, you may see screens indicating the ABS is being programmed in addition BASIC PART NO. CODE 3504 04 to the PSCM. PROGRAM CODE: If the vehicle has a constant pull and/or drift left or right, do not continue with this article. Refer to the Workshop Manual, (WSM) Section 204-00 for normal diagnostics. T12 This is reimbursable as a Pre-Defined Repair only. Claim using the unique program code provided. Since this TSB has a program code, entering the parts, labor and misc. expense details is optional. Quote Link to comment Share on other sites More sharing options...
shoman04 Posted April 27, 2012 Report Share Posted April 27, 2012 thanks you Quote Link to comment Share on other sites More sharing options...
shoman04 Posted October 20, 2012 Report Share Posted October 20, 2012 bpd1151 (2) Q. One I'm looking for the TSB for the chrome rear light pile didn't see it on the list. 2nd If you are not having a problem with a TSB item should I have that TSB done? (or don't fixs what's not broken?). Thanks You. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted October 21, 2012 Report Share Posted October 21, 2012 What I have found (at least with my dealer), that unless there is a problem, they aren't wild about performing the TSB, however, if you have a problem and it involves a TSB they are more then willing to fix it. I always have told them, if I were experiencing something and I knew there was a TSB on it, I tried to give them the number. Only exception was the brake fix on the '10's. They did that work without my experiencing any problem...well, not completely true I was getting a bit of noise from the original brakes. Quote Link to comment Share on other sites More sharing options...
shoman04 Posted October 21, 2012 Report Share Posted October 21, 2012 thanks mjhpadi. Quote Link to comment Share on other sites More sharing options...
dwmilton Posted February 17, 2013 Report Share Posted February 17, 2013 Mike, Thanks for the additional links on TSBs! I wanted to offer an alternate to the NHTSA link provided. This link will take you more directly to the "safety" items, and list TSBs. On the other link, if you fill in the info in the prominent blue box, it'll actually just return complaints, and the service bulletin info will be "zero". http://www-odi.nhtsa.dot.gov/owners/SearchVehicles Hope this helps some. I look forward to owning a 2010-11 SHO w/ PP, soon. BIG thanks to dbulldog for all the info provided, as well! Quote Link to comment Share on other sites More sharing options...
Dericlano Posted January 1, 2014 Report Share Posted January 1, 2014 Hey everyone, I'm considering buying a 2011 SHO with 50000 kms still on factory warranty. I have a few concerns; if all the tsb's are completed will I have any more problems in the foreseeable future. I love the SHO and I want one, should I get it?? I'd really appreciate some input Quote Link to comment Share on other sites More sharing options...
