My old Cougar! (The car)
Thought I'd share my old 1999 Cougar with you guys!
This was the very first car I modified so it will always be missed.
The Cougar would run mid to low 14's but it was built more for handling/autocross. When I would corner hard and hit the corner right the rear wheels would come off the ground so that was sweet! With the subframe connectors the car was pretty low, I'd scrape on speed bumps and parking lot ramps if I went too fast/ not enough angle. Anyways pics
Here's the mod list.
Modifications:
Performance:
05 3.0L Duratec built by 3LDuratec.com ported to accept SVT LIM
SVT UIM
SVT LIM
SVT TB
19lbs Injectors
ASP Underdrive Pulley
Bomz Intake /c Custom Cougar's intake extension /c K&N
Weapon-R Shorty Headers (Jet-hot coated)
MSDS Y-pipe (Jet-hot coated)
Main Cat removed
2.5" Cat back exhaust to a 3" tip
Dynomax resonator
Dynomax Welded flow-through muffler
94A Polyurethane filled front roll restrictor
94A Polyurethane filled rear/trans roll restrictor
Xcal II- Tuned by Nautilus Preformance (94oct.)
Transmission:
Rebuilt MTX-75
LUK/SVT Clutch and Slave
Fidanza Flywheel (9lbs)
Torsen Differential
Interior:
Shorty style shifter
Diamond plate floor mat's x 4
Custom shift knob /c Cougar head design
01-02 Center counsel
01-02 Headlight switch and panel
01-02 HVAC
Painted radio shroud to match 01-02 interior pieces
Exterior:
Chrystal side markers
01-02 Cougar grille
Clear corner headlights
Limo tint behind drivers shoulders
Suspension:
Intrax lowering springs
Jaged rear strut bar
Freedom Design front strut bar
BAT 21mm rear sway bar with polyurethane bushings.
TurboZetec'Tour sway bar end links (front and rear)
svt4stv Subframe Connectors
ST200 rear struts, Cougar-S front struts
Stangkiller tubular front control arms (waiting to be installed)
Stangkiller tubular rear toe arms
Wheels/Tires:
17" Centerline Storms (15lbs a piece)
Kuhmo Ecsta ASX
Audio:
HU: Sony Explod
Alpine Type-S 5x7's 50w RMS 250w max.
Rockford Fosgate Punch Amp 200WRMS@ 2 Ohms 600W Max
10" TMA by JL 200W RMS in a ported box
Pics:
Exterior/interior pics:
New motor
Interior shot
Few of my favorite shots..
Engine/trans build pics:
Engine
I do have a few older videos! This was before GoPro days but they're not bad!
This is my exhaust video after I had the 3L installed.
https://youtu.be/8kzRM3B0md0
And a few autocross videos. This was when the only suspension mod was lowering springs so no 3 wheeling.. Looks close at some parts but it's hard to see with the video quality. There is some footage of other Cougars 3 wheeling with stock suspension! It's somewhere out there
https://youtu.be/jMze9W9iJ1M
https://youtu.be/H7b2QJcoCro
https://youtu.be/0-lXKBzPn6s
Thanks guys! Yeah I wish I would have kept her too. I got to the point where I was worn out from it and sick of dealing with all the little issues, squeaks, rattles etc. I think that's why I got rid of it but it would have been an awesome weekend car.
I've seen a few around car shows but not very many to be honest, Mustangs were all the Ford really pushed for preformance cars in that era. Mval you would have loved the SVT contour! Same platform, manual, 200hp V6. Part of me wants to pick one up as a toy.
