EcoBoostSHO Posted April 29, 2012 Report Share Posted April 29, 2012 Does anyone know (or anyone with a service manual) what the voltage and corresponding temperature range for the transmission temperature sensor is? It looks like it a 0 to 5 volt signal and the hotter it gets the lower the voltage. I could approximate it with a couple of different known measuring points but I would prefer to be exact. Thanks! Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted April 29, 2012 Report Share Posted April 29, 2012 I don't find any table in the service manual that explains if this is a NTC thermistor or not, nor do I find what the ranges are for the thermistor or sense voltage. -Rod Quote Link to comment Share on other sites More sharing options...
EcoBoostSHO Posted April 29, 2012 Author Report Share Posted April 29, 2012 Okay. Well thank you for checking. I appreciate it! Quote Link to comment Share on other sites More sharing options...
