Adignan Posted July 9, 2012 Report Share Posted July 9, 2012 So I'm seeing this is how everyone is modding their SHO. Is there a post that describes how to get started? Where to buy it? How it works? Lastly, how are you getting the paint that matches your SHO? Quote Link to comment Share on other sites More sharing options...
steve142857 Posted July 9, 2012 Report Share Posted July 9, 2012 Home Depot at 6$ a can. There is only one color that people has been using so far which is flat black (actually is closer to dark grey/black with a bit of glossy). Only clean your car and make sure that is ti completely dry (not like me and some water was still dripping on the front grille and plasti dip didn't stick)... I would recommend to use a blower and let it dry an hour. Apply 4-5 coats where needed following the lines of the part of the car you are painting with over laying (you can watch on youtube actually). make sure to protect with newspaper unwanted areas (like radiator for example). Finally, or firstly, use masking tape to surround area to be painted and leave 1/2 inch all around. Make sure to spray that portion too... at the end when you remove the tape, remove that 1/2 inch of plasti dip... it removes easily and doesn't stain on the car... There you go. Wait about 20-30 minutes between coats. The only thing I found is that the finish is not like a paint, it is rubberish and if I want to dry the car after cleaning it with a microfiber clothe, I can't use it over the plasti dip because it loses the fibers... And for the front grille, it is not too bad, but it would look better if painted in tuxedo black like the rest of the car... Now it is ok, but it looks a bit cheap imo. Good luck! Quote Link to comment Share on other sites More sharing options...
gregoire Posted July 10, 2012 Report Share Posted July 10, 2012 Many how to videos on Youtube and the Plasti-dip web site. Quote Link to comment Share on other sites More sharing options...
SoCalSHO Posted July 11, 2012 Report Share Posted July 11, 2012 www.dipyourcar.com Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted August 2, 2012 Report Share Posted August 2, 2012 Have people generally found the Plasti-Dip to hold up to routine washing and maybe the occasional bug splatter scrub on grills? How well does Plasti-Dip do with touch ups? Do feathered edges blend in nicely or is it pretty obvious when a touch up happens? -Rod Quote Link to comment Share on other sites More sharing options...
sixtn39 Posted August 2, 2012 Report Share Posted August 2, 2012 I found Plasti-Dip to be very durable from bug splatters and using a microfiber wash cloth. I do use a regular terry cloth towel for drying. I have washed the front of my car several times since applying Plasti-Dip and the Plasti-Dip remains completely in place. I did do a small touch up with Plasti-Dip and brush after my initial install. You wouldn't notice it unless I pointed it out to you or you were purposely looking for it. Plasti-Dip is very cool. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted August 3, 2012 Report Share Posted August 3, 2012 Great, thanks for the info! -Rod Quote Link to comment Share on other sites More sharing options...
