Blaine109 Posted September 23, 2012 Report Share Posted September 23, 2012 During my exploratory research and discovery mission I came across a small crack on my intake tube at the connection to the turbo. Look above and slightly to the right of the red laser dot in the picture below. As you can tell, this is the intake tube that feeds into the turbo that is down near the transmission dip stick. Anyone else have this crack? After seeing this I want to take a closer look at all the plastic intake tubing. Some plastics get brittle and tend to crack with repeated heating and cooling. Quote Link to comment Share on other sites More sharing options...
Crash712us Posted September 23, 2012 Report Share Posted September 23, 2012 I'm failing to see the crack. Quote Link to comment Share on other sites More sharing options...
BombshellSteph Posted September 23, 2012 Report Share Posted September 23, 2012 Haven't had that problem or seen it much in my travels online but I do see the crack. Definitely needs a closer look I'd say. Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted September 23, 2012 Report Share Posted September 23, 2012 No crack in mine either. Blaine, so..... How are you enjoying your SHO overall? Sent from my DROID3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted September 23, 2012 Report Share Posted September 23, 2012 See the crack, I haven't checked mine but will do so in the AM. Quote Link to comment Share on other sites More sharing options...
RedCandySHO Posted September 23, 2012 Report Share Posted September 23, 2012 Does the crack go straight through? Quote Link to comment Share on other sites More sharing options...
Blaine109 Posted September 23, 2012 Author Report Share Posted September 23, 2012 Here's a zoomed in picture. It looks to be cracked all the way through and wants to start working up the side of the intake pipe. You can definitely see the gap separation on the crack. Quote Link to comment Share on other sites More sharing options...
Crash712us Posted September 23, 2012 Report Share Posted September 23, 2012 I see it now, looks like a shrink clamp. Quote Link to comment Share on other sites More sharing options...
